Results 1 to 7 of 7
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    so its not the MAF, coils, icm's, leaks, injectors,compression....
    i have tested everything. EVERYTHING checks out. i just changed my plugs out AGAIN and it runs great. the old plugs dont look bitched out at all. there BKR7E just as epl requires. what is causing me to eat these plugs up? are they just junk? what other plugs are you stg3 guys using? at this point i have to say im thinking its my software???? also the tighter gap .024 lasts longer than the recommended gap .026.
    Feb 17 2004
    Sterling, VA
    Re: so its not the MAF, coils, icm's, leaks, injectors,compression....
    Dayum! You're running a 0.024" gap?!?! That's really small.
    Just out of curiocity, what happens if you run something larger? Does it misfire uner full boost?
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    You need to get some ECUx logs and stop guessing and checking.
    May 06 2007
    Quote Originally Posted by Daft View Post
    yes it does. .026 was bad, .025 was better and .024 worked for about 2 days. does a MAF sensor just go out or can it go on the fritz? i talked with epl and im about 50 g p/s under what they are usually seeing.
    im putting my MAF on another s4 when i get home this week from work.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Agreed with dr jek. You'll have to do some logs.
    Dec 06 2007
    Calgary, AB, Canada
    Do you have an AFR gauge? Log the bugger and see what kind of AFR you're running. If you're running rich, that could be fouling the plugs.
    Jan 30 2007
    2000 S4 stg3
    cincy
    I have ECUx if you wanna drive up some time we can log and we can even switch ecus since we have the same hardware. also you may want to consider drilling holes in you airbox, this might not seem too likely but maybe your accordian is collapsing under full boost, just a thought. pm me if you wanna meet me sometime
