Results 1 to 6 of 6
    Senior Member Three Rings jaynyce's Avatar
    Nov 12 2005
    05 Audi A4 Quattro USP
    b6/b7 s4 mirror caps
    i have a set of slightly used s4 mirror caps, they are REAL! ....im askin $200 shipped anywhere, i also have an s4 front grille just add $75 its new
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Re: b6/b7 s4 mirror caps
    PMed.
    Senior Member Two Rings Eyerate's Avatar
    Aug 19 2007
    pics?
    Nov 12 2005
    Quote Originally Posted by Eyerate View Post
    pics?
    whats you email
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    pics of the mirror caps to georgiga at stu.lemoyne dot edu.....
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Veteran Member Three Rings jok3sta's Avatar
    Mar 01 2007
    N.Y.
    sup man. you get my email?
