Results 1 to 6 of 6
    Senior Member Two Rings momento1's Avatar
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    Stage 3+ and want to upgrade Coil Packs/Leads and ignition modules. Suggestions?
    as per title...
    my coil packs are dying on me... and instead of just going back to OEM i was wondering what is out there as options for upgrading all coil packs and leads along with the ignition modules (if required)
    and i have searched but came up with virtually nothing.
    Ive read a little into the nology hotwires. Thoughts???
    http://www.nology.com/hot.html
    Thanks
    CURRENT - Audi 2002 S4 Nogaro Blue Pearl - Stage 3+ 335Hp atw (but something isnt right...)
    PREVIOUS - Audi 2001 S3 Silver - 230Hp atw
    Feb 09 2007
    00 S4
    MA
    Re: Stage 3+ and want to upgrade Coil Packs/Leads and ignition modules. Suggestions?
    the only ones i've heard of are ignition solutions coilpacks that run around a grand.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Feb 17 2004
    Sterling, VA
    The OEM ones aren't that bad. They do a pretty good job even at stage 3 levels. The Nology stuff is not compatible.
    The only thing that I've seen aftermarket that is compatible as a plug&play on our cars is this: http://www.okadaprojects.com/usa/products_direct.htm
    Honestly though, there are alot of OEM coils out there.
    The S4 used a Beru coil and then had the Bosch ICMs bolted to the airbox. The ICMs are spark amplifiers and the coils just convert it and deliver it.
    On the newer cars B6 A4 and C5 A6. They use either a Hitachi coil/ICM that bolts onto the valve cover or a Bremi coilpack/ICM that pushes into the valve cover. This type of unit actually will make a stronger spark and can run larger gaps without misfires. They Bremis are also under $30 each. The current revision is "R" and they are supposed to last longer than the older versions. My car came with "L" versions and they died 200 miles after chipping the car. These "R" packs are much better. The Hitachi packs are very good, you just want to get the "E" version. ECS sells them as a kit.
    It is possible to convert your wiring to use the Hitachi packs. I saw a writeup from Jeff Lee on this a while ago:
    Here.
    This is for converting the older A4 coils (Beru Style + ICM) to the newer Hitachi coils with no ICM.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I can't believe Nology is still around. I haven't heard of them since the 90's and judging by their web site they haven't done much since then either. Like someone said before the Nology wires won't work on out cars.
    The only upgraded coil is the ones from Okada projects. They cost over $1,100 so I hope they do something. It would be great to have someone test them out and report back on the forum. Here is the link if you are feeling brave and have some money burning a hole in your pocket.
    http://www.optionseuro.com/prodinfo....OKD-PD6002101R
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 04 2008
    AUDI 2002 S4
    Sydney, Australia
    thanks for the reference guys...
    hmmm doesnt seem to be anyone thats tried the plasma coils.....
    whats the difference between the Beru coil packs and the Meyle coil packs both offered by ECS??
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by momento1 View Post
    PM Jim (onemoremile) he has the plasma coils on his A4 1.8T. I recall him saying that they were nothing special at all. He got them because he got a super deal on them.
    The difference between the Berus and the Meyles is $11ea. and the name printed on it. The Beru is the one that Audi would give you at the parts counter. The Meyle is an OEM aftermarket version. Meyle also makes waterpumps, control arms, timing belt parts and about 1,000 other parts for our cars.
    Brett - Moderator
    Issue?: email me.
