Results 1 to 9 of 9
Thread: my first code.
    Dec 05 2007
    CA LA
    my first code.
    hello all.
    i got my first real check engine light today. after leaving the exhaist show and playing with the new sound my check engine light came on. code is p1136. im guessing vac leak or maf. i dont have a presure tester so cant realy test for leaks.
    i wana try to clean my maf in the morning. can i just use the electonics cleaning spray at autozone? or is their some thing special i sould get?
    thanx
    Dec 05 2007
    Re: my first code.
    Check Mass Air Flow (MAF) Sensor
    Check Fuel Pressure Regulator
    Check Fuel Pump
    Check Intake/Exhaust System for Leaks
    Check Secondary Air Injection for Leaks
    Check Vacuum Lines for Leaks
    I replaced my MAF maybe 1 1/2 weeks ago, but I got it for cheap. Your gas mileage should also increase if you clean/replace it. Mine is not that bad, but looking at ~19 mpg for the past 2-3 months finally got to me.
    Veteran Member Four Rings TMorris's Avatar
    Jul 09 2007
    B5
    Charlotte/Columbia
    Re: my first code.
    Congrats!
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: my first code.
    I remember my first CEL in 2000.....It was a MAF
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Dec 05 2007
    CA LA
    Re: my first code.
    well i cleaned my maf and started the car. it started normaly and i gave it a few revs from under the hood and noticed a loud exhaust sound so i traced it down. WOOHOOO my test pipe broke. the turbo flang to pipe weld cracked. its not broken all the way so hopfully it will hold together till i can get it to the shop in the morning. im just going to put my stock cat back in for now. im not in a good mood. im stuck at home till morning. i dont wana chance it bracking randomly. so AAAAHHH im going to let her sit till morning and only drive her to the shop.
    Dec 06 2007
    Re: my first code.
    i hope Tom's car burns!haha j/k! he's kool! check u PM's u crazy Russian!
    -Kirk
    BetaAlphaTau Member #58
    Dec 05 2007
    CA LA
    Re: my first code.
    lol thanx. ok so cat is back in and my new muffler doesnt sound even half as good as when the test pipe was in. but have at least she's runing right
    Dec 06 2007
    Re: my first code.
    DUDE Tom can u freakin check ur PM's i like need DWAYNE'S # ASAP, he's gotta install my suspension!
    -Kirk
    Dec 05 2007
    CA LA
    Re: my first code.
    (805) 522-1303
    lol learn to use google. google competition import services and you get his web site
