Results 1 to 6 of 6
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    2nd and reverse gear problem help.
    Stage 3 is complete. While driving in 1st and going into 2nd the transmission grinds slightly only once fully in 2nd, not going into 2nd. It will go into 2nd fine, so it does not sound like a syncro problem, but once in 2nd and the clutch is 100% disengaged, it moves the car but makes a grinding noise.
    Also, once stopped the gear box will not go into reverse. What could cause this?
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Re: 2nd and reverse gear problem help.
    air in clutch line, bleed it again.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    huh?
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    www.tvme.info
    Feb 11 2005
    E46 Bmw M3
    Any other opinions. Will not go into reverse no matter what we do. This is after we installed the jhm shifter. Not sure if it was installed wrong, but 1 - 6 are great. The 2nd gear thing I mentioned is intermittent. What could it be?
    -Justin
    TDI A3 Prestige
    Dec 06 2007
    Calgary, AB, Canada
    Have you tried re-aligning the shifter?
    Feb 11 2005
    E46 Bmw M3
    Quote Originally Posted by The_Jerbel View Post
    Yes we did. The transmission went into reverse prior to the install of the solid shifter. Not sure what's going on.
    -Justin
    TDI A3 Prestige
