Results 1 to 40 of 40
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Re-finishing curbaged AVUS wheels & caliper pain
    So my Avus wheels came like this when I first got it. Didn't want to fix it at first and leave it be, but over the months of the first year, it started getting on my nerves...so now I'm working on it. Any suggestions to help me along this process would be awesome.
    Day after purchase...this is how the wheels look
    ____
    Curbage markings
    ____
    After I sanded it down with 320 Grit, and than with 800 grit
    ____
    Applied bondo to the areas that had curbage
    ____
    Applying primer to the wheel
    Now, to sand it and add paint. How does one prevent paint from running?
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: Re-finishing curbaged AVUS wheels & caliper pain
    looks good! do light coats. also, make sure you turn the spray can upside down and spray until no paint comes out when you are done with one coat. this makes sure the spray can stays good and doesn't make blotches.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by jcanni View Post
    Hm...thats good to know.
    I'll try that method on my last wheel. I also bought one of these gizmos:
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Are you going to paint the centercaps?
    l gotta-- l gotta get
    a form from a scientist.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by TommyGunn View Post
    Yup...it'll be the last step in my process.
    How do you get rid of the scratch markes on the plastic center caps? Sand it?
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Two Rings BMCINSD1's Avatar
    Oct 03 2007
    Audi S4
    San Diego
    Which brand of paint are you using for the wheel?...
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I'm doing this right now to my stock wheels. Only I'm using JB Weld instead of bondo. I have the same type of mark/curbing. I'll post some pics of my process...
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by BMCINSD1 View Post
    Dupi-color from Advance Auto Parts.
    2015 B8 SQ5
    Click Here
    Past
    Dec 02 2007
    DC/MD/(VA)
    Quick Update
    Painting my wheels and doing my "FA-REMBO" (Fake ass Brembo) set-up
    2015 B8 SQ5
    Click Here
    Past
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Quote Originally Posted by Kruat View Post
    ive been refinishing wheels like a maniac lately, and jb weld is MUCH better to use than bondo. also when powdercoating, you cant use bondo as it wont hold up to the heat whereas jbweld can. just note that sometimes the coated area over jbweld is a different shade of color, so i usually use a primer coat before coating.
    also sandblasting the wheel would be much easier to clean up the wheel ... if u have access to one
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Dec 02 2007
    DC/MD/(VA)
    With a little helpful tips from my dad, this is the results of my first wheel job. Now onto the rest of the three.
    Wheel #1:
    AFTER ACTIONS TIP: When adding primer, ADD more than one coat; at minimum two coats.
    2015 B8 SQ5
    Click Here
    Past
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    i would suggest sanding after the second or third coat of primer... then two coats of color and two of clear, then wetsand with 2000, 2500 then 3000 and buff it out... that would get rid of that orange peel and give it a glossy look!
    not bad for your first try man
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by 317ssayzarc View Post
    Thanks man. The orange peel effect is given off by the light, there is no orange peel color.
    Sand with wet 2500 works after you've added the paint on? The paint won't strip?
    AFTER ACTION TIP: Wet sand is WAY better than dry sand (under certain circumstances)
    2015 B8 SQ5
    Click Here
    Past
    Oct 27 2007
    In the lab
    I wetsand scratches out of panels on cars when I detail, wheels are just paint as well... As long as you get a good hard clearcoat on there you can sand away... I'd start at 2k and work it up to 3k then get at it with a rotary/compund on the face and a drill/compound/powerball in the spokes... I'm a little obsessive lol
    Dec 02 2007
    DC/MD/(VA)
    Hm. Learned something new today.
    2015 B8 SQ5
    Click Here
    Past
    Oct 27 2007
    In the lab
    Awesome, glad I could help
    Some dont like being schooled, I think its an ego thing, but I personally enjoy it
    Dec 02 2007
    DC/MD/(VA)
    Last post of the night...gotta get up at 5am.
    My FA-rembos setup 50% complete!
    2015 B8 SQ5
    Click Here
    Past
    Dec 02 2007
    DC/MD/(VA)
    ^^ Decal or no decal?
    I'm thinking the decal would make it look tacky.
    2015 B8 SQ5
    Click Here
    Past
    Nov 10 2004
    Longview, WA
    Dunno man, but I've yet to do this. I have some red caliper paint as well. I wondering if red will stand out too much for stock brakes...I might get some black.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Dec 02 2007
    DC/MD/(VA)
    What do you gents think?
    I think I did a decent job but I'm a little unhappy with the paint job AND that there is a noticeable spot where i wiped off some grease that accidently got on the wheels.
    Now to complete the other 2 wheels and my re-finishing project is done
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Two Rings galvan11's Avatar
    Aug 20 2007
    02 pearl gt s4, vw passat, 06 cbr
    south
    Looks good..
    A buddy and I took 26 hours straight without sleeping to get our wheels and calipers painted! Never thought it would take that long!
    All the paint fumes and thinner did the trick to keep us awake!
    Dec 02 2007
    DC/MD/(VA)
    Gents, I've finished my wheels and caliper project (wheel caps will be completed later). I'll post pictures of the wheels and the car when the weather is a little nicer.
    Refinished AVUS wheel on the left, Original Avus wheel on the right
    Refinished
    Original
    Now to schedule an appointment to mount/balance/align my FALKEN 452s
    2015 B8 SQ5
    Click Here
    Past
    Nov 10 2004
    Longview, WA
    Did you paint the barrel?
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Dec 02 2007
    DC/MD/(VA)
    No. Now that you mention it, it IS very noticeable.
    DAMN!
    2015 B8 SQ5
    Click Here
    Past
    Nov 10 2004
    Longview, WA
    Well the reason I ask is, once I get to painting mine, I was wondering if I should paint the barrel, but I'll most likely be going gunmetal, so it would be really noticeable.
    BTW-yours look great! Good job man!
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    very nice
    B5 S4 AWE Stage 3 - sold
    Dec 02 2007
    DC/MD/(VA)
    PAINT THE BARREL when you do it!
    LoL! Learn from my mistake! If I were to paint the barrel, it'd probably be the same steps as painting the front but more cleaning. Tip suggestion, don't over paint the barrel portion, just enough that there is color on that side AND there won't be any noticeable running when you turn to paint the front.
    Thank you, thank you gents
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Great work...Duplicolor makes great rattle can paint.
    Jun 14 2007
    2000 S4
    Connecticut
    did you do the entire caliper in the front ? looks like you just did the face of it ? this is my caliper when re done with duplicolor but it wasnt a spray can it was a paint brush caliper kit
    looks great though, the wheel job came out great
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    stop bein such a rich greenwich kid
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Quote Originally Posted by AMC83189 View Post
    haha..
    OP - Your diy looks great.. Good first job. I am about to undertake this on my car although now thinking about it I might have the wheels off the tire and give it a shot. That way I can work on them longer and take my good ol time. I think Ill give JB weld a try instead of bondo though.. I think that would probably last a little longer with the wheel.
    Cheers
    Dec 02 2007
    DC/MD/(VA)
    Pretty much. I basically did a 180-degree caliper paint job, so everything you can possibly see up close and far away is red. Everything else inside the barrel and behind the calipers, I left alone.
    Theres some things I'll take out and work on, brakes is not one of them. I like to stop.
    Yes. I do recommend you taking off the entire wheel to do your paint job. Its easier and allows you to do a better job. On top of that, it allows you to paint the barrel portion of the wheel. I'm doing that today, I hate the fact that I missed the barrel portion; looks funny.
    Is there any suggestions on what/how I should paint the center caps?
    2015 B8 SQ5
    Click Here
    Past
    Jan 16 2008
    '15 S5, slippahs
    Home
    Good job man, looks like new now.
    Dec 02 2007
    DC/MD/(VA)
    F**K!
    My center caps and wheel are two different colors!
    Does anyone know how to fix this?
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    looks great, sounds like a fun project to paint the calipers
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Senior Member Three Rings Ber\/ani's Avatar
    Jun 03 2007
    Sacramento CA
    F**K!
    i used electric tape and very tightly taped around the center black ring as well as the grey w/audi rings portion. let it dry for a while, i peeled the tape too soon and took off some paint. but yeah electric tape worked pretty well.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by Ber\/ani View Post
    Nono. I did the same thing you did. The entire center/wheel cap is lighter than the wheel itself. I'm thinking its because I ran out of paint, so there wasn't much left to cover. If thats the case, I'm buying another can to finish it up.
    If not, I have no idea how to fix that...
    2015 B8 SQ5
    Click Here
    Past
    Dec 02 2007
    DC/MD/(VA)
    Officially Finished
    I'm done. Yea, no more progress pictures
    Wheels, Wheel caps, calipers, new tires and a car wash!
    2015 B8 SQ5
    Click Here
    Past
    Nov 10 2004
    Longview, WA
    Those look very good man. Very nice DIY.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Nov 20 2007
    01.5 S4
    uh oh...... this is going to be a thread jack flame war.
