Results 1 to 37 of 37
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    people who have installed rieger fronts
    i searched. . . when i am fitting the rs4 bumper, where do i put the screws in the fender?
    i have searched. but could not find any installs that showed. all of them just showed the gluing.
    thanks in advance.
    why didn't i buy a rs4 gill when they were $60
    Jan 26 2007
    Saint Paul
    Re: people who have installed rieger fronts
    20 views?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    id like to know as well, this thing is very vague when it comes to mounting and reiger doesnt offer support as they dont make this bumper anymore
    Deactivated Two Rings str8kustom's Avatar
    Jun 11 2007
    2000 Audi A4
    New York
    what i did was where bumper reinforcement is i drilled the holes in the bumper so i can use the existing screws. the long ones. you have to adhear the reinforcement from your old bumper to the new one(rs4). then you will be able to work on the sides once that is on. what i did so it didnt look to smashed up against the fender was i drilled on the inner liner of the bumper to the supports on the sides. i used self tap screws i did x3 on each side. holds up very sturdy and looks good. i just took mine off. when i put it back on i willl take pics. hope that helped
    Oct 27 2007
    In the lab
    so you just put 3 screws thru the fender liner into the bumper on the sides?
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by 317ssayzarc View Post
    Yup I used 2 that's all you need. I actually pulled it and am trying to make a bracket to use that will not crack and chip the Rieger skin, which has happened to mine and will happen to your's probably because I imagine you'll be pulling it on and off alot like myself.
    Oct 27 2007
    In the lab
    yea i was thinking of making a metal bracket with nuts welded onto it and putting bolts thru the fender liner into the bracket with the bumper inbetween... what you think about that?
    Sep 24 2005
    always in design
    I like that idea, but possibly do the reverse with the bolt welded and the nuts being free. I'd do the bracket on the fender and the bolts going through it, with the nuts going on inside the fender lining.
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    i did 3 screws into the wheel liner. as well as 2 vertical screws into the fender where the fender is flat and the bumper meets it. works perfectly
    --beejohn
    2001 A4 1.8TQMS
    Jan 26 2007
    Saint Paul
    does any one know of a install writeup with photos?
    Sep 24 2005
    always in design
    Quote Originally Posted by dmaize View Post
    Not to my knowledge, but I can shoot some pictures later this afternoon of how mine is installed. My bumper support is independent of the skin these days and that is how I'd recommend people install it. That type of install makes pulling the bump skin on and off much easier IMO. I have been thinking about the bracket Issac and I mentioned above and I spent an hour at Homie D today trying to find just the right connection but could not. Came home and looked online and I think I found a good solution though Self Ejecting fastners they have a bunch of other items that may work as well.
    Oct 27 2007
    In the lab
    Quote Originally Posted by bassed View Post
    do you just use spacers to adjust the height of it? how would it sit level otherwise?
    Sep 24 2005
    always in design
    Expanding foam That way there is only one way it can fit, which would be perfect
    Oct 27 2007
    In the lab
    ahhh, i see... thats very creative since i always am working in the under the bumper area... ive put 300+ miles on the car w/o a bumper so far lol, havent gotten pulled over yet but i want to mount this thing asap once ER makes a revised batch of rebar
    Sep 24 2005
    always in design
    As long as you run the bumper support you're technically legal I ran that way for 2+ months with a 80mile round trip commute 5 days a week, before I grabbed a 2nd car
    Oct 27 2007
    In the lab
    i was told this is not the case in RI, but even if that was true, i still need my rebar from ER
    Oct 27 2007
    In the lab
    just found this from the RIDOT inspection booklet:
    3.6.1 BUMPERS - Passenger type vehicles
    Inspect every passenger type vehicle for bumpers (front and rear) according to the original manufacturers’ specifications.
    Jan 19 2008
    The rebar is technically the bumper just like you see on trucks or Jeeps which have metal bumpers with no skins. The bumper "cover" doesn't do too much for safety and is more for aerodynamics. You should be fine without running the skin but IANAL.
    Oct 27 2007
    In the lab
    Quote Originally Posted by T3hD0gg View Post
    in that case i may just weld me up a rebar and bolt it on
    Sep 24 2005
    always in design
    Just run it like this and be done with it
    Oct 27 2007
    In the lab
    i just might until ER gets going on the production... i like to show the coolers up front anyways lol, its intimidating imo
    Sep 24 2005
    always in design
    What Oil Cooler setup is that again? I know USRT has a complete kit I'm eyeing up, but I'm running out of room I started on my Snow Stg 2 kit today and realized with my piping and all the other crap I have no room anywhere for the pump and will need to think long and hard before I go installing it
    Oct 27 2007
    In the lab
    http://forums.vwvortex.com/zerothread?id=3797522
    check that thread... im crazyass713 and jacob@ina
    Dec 08 2006
    Cincinnati
    Quote Originally Posted by beejohn View Post
    Yup, I second that. But I have 2 screws into the wheel well liner and 1 screw vertical into the fender (per side). It kind of just sits on there, need to figure out more secure way.
    Established Member Two Rings Pointmeby's Avatar
    Nov 25 2004
    05 GT3, VW Beetle
    Orange County - CA
    I just converted mine from screws into the fender to Dzus fasteners. (Self ejecting fasteners) Much cleaner and easier to use. The screw the bumper into the fender method was pretty ghetto and eventually cracked the bumper skin.
    The Dzus fasteners are mounted in the fender liner so they are invisible as well. Let me know if anyone wants to see pictures.
    Oct 27 2007
    In the lab
    Quote Originally Posted by Pointmeby View Post
    of course we do lol, please post em up
    Dec 08 2006
    Cincinnati
    Yup, 2nd that. I have never been pleased with how my bumper mounts, and have broken off multiple parts of the inside of the bumper skin (the stiff parts in wheel well that connect to wheel well liner).
    Sep 24 2005
    always in design
    Did you use the kind I linked to above?
    Registered Member Two Rings _audible_'s Avatar
    Apr 19 2007
    A4 and a S13...
    VA
    I had mine ziptied to the fenders. No sag, lasted couple of years.
    Sep 24 2005
    always in design
    Quote Originally Posted by _audible_ View Post
    BTDT it's not condusive for those of us who work on the car alot and constantly take the skin on and off. It also doesn't produce a great fitment IMO.
    Nov 25 2004
    05 GT3, VW Beetle
    Orange County - CA
    Here's some quick (and dirty) images of the install.
    My fender liners are pretty beat up from running oversized track tires.
    The Dzus fastener in place:
    Showing the fastener and catch:
    Installed:
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    nice setup, might have to try that myself
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    hmm, i might need to try that was well. do they fasteners hold pretty tightly? im just curious if that would pop off over some road vibrations.
    how the hell do you get those fasteners on though?
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Dec 11 2006
    Boston
    My reiger is held on by 2 bolts on each of the fenders. It lines up perfectly, no sag, AND it comes off and on in about 5 minutes.
    Stage 3+ RS6's
    Feb 23 2005
    if installed correctly dzus fasteners will not come off. they are spring loaded, with a twist to turn.
    Dave
    Nov 25 2004
    05 GT3, VW Beetle
    Orange County - CA
    A general idea of how they are installed:
    http://www.s-sengineering.com/
    I have a backing support on the one that goes into the ABS fender.
    It takes seconds to remove each side. Put a screwdriver in the slot and turn.
    The fasteners lock into place with a spring. I haven't run a track event with them yet, but they are race-type body fasteners so I don't see them popping out.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    good to hear. i may do this sometime if i find the energy...lol.
