Results 1 to 12 of 12
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    New downpipes....how to???
    so yeah,got some downpipes, pretty confident with installing them myself. But im wanting to be on the safe side and time is essential for me to get the job done. anyone know any good resources with pictures on how to remove and install? i have found some that are very vague and i have the idea but i would like to have more confidence on my side. Anyone with any help let me know, im struggling to get my S4 to stage 2.5 but need some experienced advice. thanks a lot
    Established Member Two Rings kh973's Avatar
    Oct 23 2006
    Re: New downpipes....how to???
    Is your car Automatic or Manual? This is the guide I used
    http://www.audiworld.com/tech/eng43.shtml
    No pictures but its pretty straight forward once your under there. Ive put them on an auto and a six speed and the auto def takes more maneuvering out to get them out from under there.
    2001 Laser 6sp stage 2+
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by kh973 View Post
    Its a good guide, only I must have pictures when I do stuff like that. Otherwise I have no idea what the hell some things look like.
    Feb 20 2008
    Savannah, GA
    thanks for trying but that us the how to i tried using. I mean i am a helicopter mechanic, and i get lost doing some stuff on my s4. Is there a manual i could buy that would be straightforward with pictures?
    Feb 20 2008
    Savannah, GA
    oh yeah its a 6 Spd.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    search under pigges and you'll find some good info. the removal and install is not that bad, i would say if you are working on jacks and have air tools you can get it done in about 8+ hrs, this all depends on how rusted on the downpipes to turbo bolts. I'm in OH and it took about 30mins/bolt (4/side) a bolt and a full can of PB Blaster due to nature of this problem.
    Get some ratchet wrenches with flexible heads, this will make it go a lot smoother.
    You can also look at the AWE-tuning site, i believe they have a write up for their downpipes.
    B5 S4 AWE Stage 3 - sold
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    OKAY, personal experience here.....if you are doing this on jackstands, it will be a weekend project, and I mean ALL DAY sat and sun and the evening of friday if you can manage that as well. Also, you need to remove the tranny mounts if doing it on jackstands, i don't care what other people say, it took me 1.5 days just to get the drivers side DP off and the flange that bolts to the exhaust manifold kept getting caught on heat shields and the tranny mounts....a lift would be ideal
    Also, there is no write-ups w/ pics (atleast that i found) when I searched, and I looked really hard b/c I am kinda the same w/ needing pics. You will also need to go rent the O2 sensor tool from autozone or get a crows foot, this tool is essential, and that drivers side front O2 is a BITCH! Oh yea, and a buddy to help is also very very very helpful
    GL and hope this helps.
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Nov 23 2007
    Columbus, OH
    I did it on jack stands and I did not remove the tranny mounts, so dont be discouraged
    Crows foot is definetely neccessary for removing the o2 sensors
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by 2fastS4 View Post
    Strong second to everything you said, except I did not remove tranny mounts. It took all weekend on jack stands.
    Feb 20 2008
    Savannah, GA
    would one of the bentley manuals give detailed pis on removal of the downpipes? i was thinking about getting one of those, it would be worth the money.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    on jack stands; drop the subframe. that makes it easier to get to the dp bolts. as earlier stated.. its a job
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by ThirdStrike View Post
    ha, yea, almost forgot about those bolts, GL w/ the third bolt, thats a bitch for sure
    MKIV BPM R32 (DD)
