Results 1 to 6 of 6
    May 21 2007
    Nashua, NH
    CV Boots or New Axles?
    Before I left in January I had my car checked out. I noticed that both my front outer cv boots were torn. So after being away for 5 month now when I drive my car and turn the joints start the click. I was wondering if I can just replace the outer halves of both axles or should I just replace the whole axle?
    Also I'm planning on doing this next week. Is there a DIY writeup anywhere for this job? I have done an axle before but it was on a Jetta. Thanks
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Re: CV Boots or New Axles?
    replace the axle www.raxles.com they will take care of you you can get a refirbushed 1 and send your in as a core or you can buy both inner and outer cv joints for real cheep come wit everthing
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    PureMS whole shafts. Don't need to send your old one and they are cheaper than raxles.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    if they are ticking, replace the whole axle
    May 21 2007
    Nashua, NH
    Thats what I thought just double checking. I've seen a few write ups on here and it seems like it shouldn't be very difficult to accomplish.
    Dec 06 2007
    Calgary, AB, Canada
    clicking joints just means that there is no more grease in the joint, and they're dry. Take the joint apart, clean it out, visually inspect the joint. If you don't see any significant scoring, just put the joint back together, re-grease it, and install a new boot.
