Results 1 to 24 of 24
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Couple Meth/Water Injection questions
    First of my engine is stock. I been reading up on the Boost Cooler kit.
    1. Does Meth/Water increase gas mileage?
    2. Can this system be run constantly(daily driving)?
    3. Would I need to adjust my ECU to run this system?
    PS. I'm not really looking into a Meth/Water injection system, but rather an HHO(Hydrogen) conversion kit.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    Re: Couple Meth/Water Injection questions
    Quote Originally Posted by manhertm View Post
    1. Maybe, but that's not the reason.
    2. They should only be used under boost
    3. ECU will need to be adjusted. Timing, Afr's, ect.
    4. Skip it.
    I also see your on an ebay budget. Well, if that's the mentality you take for WI, you will be buying a new engine.
    USP CLUB MEMBER #686
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Grenade View Post
    4. Skip it.
    Meh, I guess, I'll never know until I blow it up.
    Oct 29 2005
    10speed
    San Francisco, CA
    1. yes
    2. yes
    3. no
    as an added bonus, its awesome
    - Clint
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Fuck it, I gonna let you guys in on what my girlfriend said I can try on her car.
    http://www.vadaenergy.com/products/03packages.html
    If this kit does work, one is going on the B6. Been reading up a lot on this and technology is getting a lot better for these kits.
    Oct 29 2005
    10speed
    San Francisco, CA
    wtf is that? and u think that fuel controller is going to work on a B6 ECU? It seems like it is like a meth injection?
    - Clint
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Here's simplified layout of how the system will go in. It basically uses an electrolyte mixture of water and the cell separates the Hydrogen and Oxygen molecules into gas, which is then connect via a hose to the intake.
    My girlfriend has 02 Mercury Cougar, so I dunno.
    Oct 29 2005
    10speed
    San Francisco, CA
    so it just puts straight water in? Water meth would be a better option?
    - Clint
    Jan 21 2007
    "Old Yella"
    san antonio tx
    The air/fuel ratio can be adjusted via software right?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    No, I don't think water i even injected. It converts the water from the fuel cell into gas. Then it is pumped into the intake.
    Oct 29 2005
    10speed
    San Francisco, CA
    ah so the hydrogen (an explosive gas) is injected right into the engine? I would imagine thats not too safe but it says it is well see
    - Clint
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well, I've been a huge skeptic of this for a while(2.5 years to be exact). I've been checking out Youtube vids on the subject and the question is not whether it works ,but more how to regulate the system. Vadaenergy's kit is the first comphresion package, I've seen for this. Usually other websites have instructions on putting togther a fuel cell from scratch.
    Oct 29 2005
    10speed
    San Francisco, CA
    why wouldnt water/meth be the same tho? i mean its a combustable mix being shot into the engine
    - Clint
    Jan 21 2007
    "Old Yella"
    san antonio tx
    That was kind of what I was trying to find out in the original questions. The major difference is the fact with the HHO system, its gas and not a mist, so I guess it burns more completely. I don't know how hydrogen compares with methanol as far as being combustible. I think the fuel controller in the VADAEnergy kits connects to the O2 sensor to lean out the engine when the hydrogen gas is being injected. Thats where the increase mileage comes in.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Here's couple vids what's gonna happen.
    The first is from Mythbuster's.
    http://www.youtube.com/watch?v=ydEkV-E0mP8
    The other two are just two guys with they're own homemade system.
    http://www.youtube.com/watch?v=5EBml...eature=related
    http://www.youtube.com/watch?v=YFGhZ...eature=related
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    yeah....uhh thats not going to make NEARLY enough hydrogen to power an engine...ahem ahem MYTHBUSTERS.
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by AudiBama View Post
    Did you check the Youtube vids I posted, with said Mythbusters vid.
    Oct 29 2005
    10speed
    San Francisco, CA
    yo I say you do this, it sounds badass
    - Clint
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    Wasn't the Hindenberg made of Hydrogen? That worked out pretty well. Has this thing been proven on any amount of different vehicles? Has it been tested enough to know that it won't cause damage to the car?
    WTB K04 turbo ASAP
    http://etektuning.com
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by evola4 View Post
    It was made with an incendiary paint and check youtube for some proof. I'm not saying it's perfect, but I have enough confidence along with VAG-COM logs to try.
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    To be honest, I don't have high hopes for this, but I am very interested to see your results.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Feb 17 2005
    Sarasota, FL
    Water/meth is not combustible
    Feb 17 2005
    Sarasota, FL
    With a standalone, not with standard software
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by A4ringedONE8T View Post
    Is there another way to lean the system out.
