Results 1 to 4 of 4
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    Check Engine Light
    Does anybody know how to get rid of check engine light short of putting cats back on the car? I already tried the defoulers (they didn't work).
    Oct 31 2005
    Ashburn
    Re: Check Engine Light
    Which defoulers did you use? i didn't have any issue's with the ones i bought from VAST.
    - Instagram: @Sinister_rs5-
    Jan 22 2006
    nguyen
    I have a set of VAST defoulers if you need them. Sell them at retail cost, but with free shipping.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    What are the codes you are pulling? Are you sure the cel is from the exhaust?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
