Originally Posted by
LateApex
You may want to go as far as to downsize from your 19" rims to some lighter 17's that require less travel when you're just commuting. When you upsize that much you can really screw up the gearing unless you have some serious low-pros.
Sorry, but that's simply not true. When going +1, +2, or more, if done correctly, you maintain the overall diameter. While increasing the wheel diameter, you should decrease the sidewall height accordingly (decreasing the tire's aspect ratio).
There are many online calculators to help determine the correct tire size when going +1, +2, etc. However, the formula is:
tire width x aspect ratio / 25.4 (changing from metric to inches) x 2 (two sidewalls per overall diameter) + (wheel diameter) = overall diameter
225/45/17 = 24.972"
225 x .45 /25.4 x 2 + 17 = 24.97"
Same goes for 225/40/18:
225 x .40 /25.4 x 2 + 18 = 25.086"
As you can see, the overall diameter didn't change very much at all. (.11")
What DOES affect your gas mileage with larger diameter wheels is the added overall unsprung weight.
With all of that said, it looks like I'll be doing a fuel filter (I remember it being a PITA in my B5), both oxygen sensors and plugs soon.
Mike
