Results 1 to 40 of 51
    Established Member Two Rings marfcus's Avatar
    Oct 31 2006
    Like a glove.........[FMIC content] *Updated with more pics*
    I've been playing around with idea of a fmic for a while now and have had the core, piping, clamps, etc. sitting around my house for quite some time so i finally decided to piece it together. I've been reading all the fmic and gathering all the info i could to make it easier. After seeing the JHM fmic and realized you could really make it all fit and not have to ditch all the grille mesh i was determined to make it work.
    Took me about 7 hours to complete everything and get it to fit the way i wanted. Everything i got off of ebay. Core is from CXracing along with the piping. I decided to go with 2" out of the turbo and then from the intercooler to bi-pipe went with 2.25" to eliminate the old side mount hoses which make some tight bends in a short area and definitely seem restrictive. I didn't want to deal with hoses and clamps everywhere either so i welded everything solid. The only places i have had trouble with the pipes popping out is from the hoses that come off the turbo so i welded a bead on those and have since been fine. I really think that the key to making it fit behind the grilles is you have a 45 degree angle coming right out of the reducer on the core. Probably going to paint the pipes black soon too just to make it even more sleeper.
    Also went ahead and cut out behind the front plate cover for whenever i feel the need to optimum air flow to the core. But for everyday it's nice to just snap in the cover and go stealth.
    Here's a little IAT graph from the other day. 80F and 80% humidity. I'm pretty happy and impressed considering the stock ICs would start at 110 - 120 and climb past 140 easily in 70F weather at the same boost levels. The car is definitely faster! Way more consistent and seems to be smoother. All in all i'm pleased with how everything turned out.
    2011 A4 Avant
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    Re: Like a glove.........[FMIC content]
    You are the man
    Jun 14 2007
    2000 S4
    Connecticut
    wow, AWESOME job!
    Mar 20 2008
    Italy
    Awesome job man!!
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Wow! Seeing this is definitely a motivation towards the much cheaper, efficient FMIC. I was going to go to ER route a while back, but seeing that these are just as good I plan on buying the JHM kit when it comes out.
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Nice work man! It looks like you didn't even have to shave the mesh to clear the IC endtanks. How much space do you have in between the intercooler core and the A/C condensor?
    B7 S4 Avant
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    See.. Like ive said 100 times.. With a little time, thought and a little creative bug, it will fit fine.. Good job bro!
    Oct 31 2005
    Ashburn
    Fucking awesome, now all i need to do is clean mine up. The cleanist ebay frountmount by far.
    Good job
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    looks great! Can you take some pictures with the bumper off? Maybe a little writeup?
    the homebrew'd s4
    Oct 31 2006
    Thanks for all the compliments guys
    Quote Originally Posted by BlackS4TT(Josh) View Post
    You are right, did not have to shave the mesh at to clear the endtanks . The only place that i shaved a little off of was the driver side lower mes and that's because it's the 2.25" pipe. If it was a 2" pipe i don't think you would have to shave anything off off. I probably have about a 1/2" between the core and condensor. Oh yeah check your PMs, it's regarding the ECU. Thanks Josh
    Quote Originally Posted by Overboostin View Post
    I have some pictures of everything with bumper off but it's from the first day i worked on it so only the passenger side was welded and part of the driver side but i will post them anyways. I will get a hold of the camera soon and get some shots with everything welded. I was thinking about a write up but i'm not sure if i will or not but i don't mind answering questions about how i put it together and what i used
    2011 A4 Avant
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    That looks great, any hope of saving foglights?
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Great work!
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    I LOVE THE THREAD TITLE!!!!! Ace Ventura anyone?
    http://youtube.com/watch?v=3nOxdKcqC_I
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    ^^^ I technically beat you
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by grAh4m View Post
    I posted that because you posted #1.
    You beat me? What is this, VWVortex?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by Rated S View Post
    Hahaha the first one is sooo much better. Don't even kid yourself!
    (I'd have no idea what vortex is like. I hate that place)
    Oct 31 2006
    Quote Originally Posted by Kruat View Post
    Yes! Believe it or not the driver side fog fits but you have to turn connector vertical. Passenger side fog was a close fit but i need to tighten the bend on the passenger side lower to make it fit. I'm probably just going to go with after market fogs though. I believe BlackS4TT (josh) has the stock grilles, mesh, and fogs still in place with his FMIC setup.
    Glad someone caught onto it
    2011 A4 Avant
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    That looks awesome... very clean install.
    Nice IAT numbers too, that eBay core is surprisingly good.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    great job!! sleeper status ftw!
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Mar 15 2007
    New England
    I can't wait to see some pictures without the bumper. It will help out installation a lot.
    the homebrew'd s4
    Mar 14 2007
    michigan
    Nice job, but I haven't seen 1 ebay cooler at the track or on the dyno really get lower then 145 ait most were in the upper 150sss on 50-60 days....
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    great job!
    Innovate.
    Oct 31 2006
    I should have those pictures by tomorrow. Just need to get them off my gf's camera
    2011 A4 Avant
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    looks clean kid. nice work. you clamp everything down well? you pressure test it for leaks? its such a PITA when the pipes blow off, but after you clamp them down, it should be a go.
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    wow man, that is probably the cleanest FMIC install i've seen yet, w/ the grills in and everything, great job!!!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Registered User Three Rings S4M3's Avatar
    Jul 12 2007
    B5 S4,B8 S4, E55 AMG
    Atlanta, GA
    I need Aluminum welder .... :)
    Veteran Member Three Rings SilverBiturboS4's Avatar
    Sep 14 2006
    Dallas,tx
    its looks very nice. I like how u kept the Front plate filler there for stealth mode and was able to take it off for more air flow and track mode. wanna do mines for me? Ill pay. haha
    2001.5 S4
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Very nice, congrats.
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    beautifull two thumbs up
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    i vote write-up!!!! :-D and great job on that one..
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Nov 30 2006
    annapolis, maryland
    One thing people may also want to note, is that he used alot smaller piping and that also gave him mroe clearance. Mostly everyone that is running 2.5" that goes to 2", will prolly be able to pop the grills back in. Making 2.5" work sucks, but can be done with a little time. I came out with alot of scarpes and scratches on my hands though. lol
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I generally like the SMIC better because of the stock look. But this does look good. But gotta get those fog lights in there. Post up some pic's when you get the aftermarket ones in you were talking about.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Mar 15 2007
    New England
    bump for pics!
    the homebrew'd s4
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    very clean! one of the best FMIC installs/fitment i've seen on an S4 so far
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 17 2008
    Ottawa Ont.
    Mar 15 2007
    New England
    the homebrew'd s4
    Oct 31 2006
    Quote Originally Posted by BastardS4 View Post
    My chef's cap for FTL
    Anyway here's some pics of everything when it was half finished and not fully welded but you get the idea.
    Some fine examples on the lower pipe of measure twice cut once
    Shaved a little off the bottom grille for a little more clearance
    2011 A4 Avant
    Mar 15 2007
    New England
    looks great! thanks for the pictures. what piping kit did you get?
    the homebrew'd s4
    Oct 31 2006
    Exact kits here Got the core from the CXRacing also
    CXracing 2"
    CXracing 2.25"
    2011 A4 Avant
