Results 1 to 3 of 3
    Established Member Two Rings vovpar's Avatar
    Nov 30 2007
    04 S4
    Sacramento, CA
    Location of an Airbag Module on S4?????
    So where is it located on the S4???
    Many Thanks!
    04 S4 6Speed DOLPHIN GREY~iForged~APR~REMUS~Sebring~
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: Location of an Airbag Module on S4?????
    I'm not sure about the B6 but the B5 was right in front of the shifter on the tunnel, so you may want to check there.
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Pop off the plastic underneath the E brake, and you shall see airbag module.
    Now.....to remove airbag module, have fun taking out the entire center counsel assembly =)
