Results 1 to 4 of 4
    Senior Member Two Rings maciej-xx's Avatar
    Apr 30 2007
    b5 S4 Avant; mk7 GTI
    Thornton, CO
    Plugs Drowned in Oil
    So i had problems starting my car yesterday... When I've pulled the cap from the spark plug, the oil was dripping from it... All the plugs on both sides (V6). There was so much oil there that I could not even see the tip of the plug on some of them (not all). I just hope, it's gaskets...
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: Plugs Drowned in Oil
    Probably the valve cover gaskets.
    Senior Member Two Rings tonelee1316's Avatar
    Oct 10 2006
    rancho cucamonga
    was it when u pulled the spark plug wire off the spark plug was covered in oil= valve cover gasket. if you removed the spark plug and the electrode was coverd in oil it would be rings/head gasket
    Genesis Autosport
    Evolution Racewerks
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by generik777 View Post
    X2.
    If your spark plug wires are swollen where the oil had been "drowning" them. They should be replaced. The might still work for awhile, but it's recommended that you replace them.
    I think I replaced my plug wires for $68 from Bahn Brenner on my 12V.
