Results 1 to 18 of 18
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Drivers window acting up.
    Sometimes, when I put the drivers window up (auto) it goes all the way up, then comes back down 5 inches. It will do this several times, almost as if something is in the way. I've checked and everything is clear of obstructions. I then have to manually hold the button to close it. After that, the auto function no longer works for a while. After a day or so, the operation seems to return to normal. Anyone else see this? I have not yet queried the dealer.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Drivers window acting up.
    Muhahaha... Welcome to summer. This is a common problem on our cars and it typically requires a new window regulator. Heck in under 2 years in phoenix I've had 3 replaced already...
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    just had mine replaced...300 dollars...its deffinatly the regulator
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    oh shit really? that happened for hte firs ttime to me today!
    Veteran Member Three Rings s4_fishingbean's Avatar
    Apr 13 2008
    B7 S4
    Ft. Lauderdale
    happens to me all the time too
    Sep 26 2006
    Nor Cal
    Yes! Under warranty! (extended)
    Active Member Two Rings Mokes's Avatar
    Oct 10 2006
    2010 Honda Element EX
    Downtown L.A.
    Yup, me too. Already had to fix both sides at 27,000miles.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    mine does that too! hasnt happened in a month or so though. i thought it was because of the vag-com window mod.
    Senior Member Three Rings A4TuNeD's Avatar
    Mar 21 2007
    Sarasota, FL
    It could be the regulator as said above, I got mine replaced last week. but not only does the window not go up very easily but for me it was making a really loud crunching noise almost as if a quarter was stuck. My service manager said that is typical.
    06 A4 2.0T
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    And it's caused by hot weather?
    Mar 17 2007
    new york
    Quote Originally Posted by A4TuNeD View Post
    same thing with me..
    Registered Member Two Rings
    Jan 30 2008
    Boston
    Got a brand new 07 S4 and that happens to me as well. SUX
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    mine just completely stopped working on the driver side. In fact it was grinding for a while and made the most terrible sound in the world and scratched the hell out of my tint. It was replaced under warranty.
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    mine does the same thing... every once in a while it will go all the way up, then come down a few inches... i think the weather has something to do with it, as it seems to do it on hot days...
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    I have had that issue on several of my VWs.... '01 GTI, '04 Passat
    4Mo, '02 Jetta Wagon... and also on my '01 A4 1.8T.
    Must use the same regulators.
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    my friends vw did it for a year, got worse too. Started to come all of the way back down.
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Veteran Member Three Rings TunaRollZ's Avatar
    Feb 20 2007
    911 TT/A5 3.2L/S4 4.2L
    Sunnyvale CA
    chalk up another dead regulator here.
    one hot day i rolled down my windows and the PS front one made loud crunching sounds. scared the shit outta me. Then it refused to go back up. I had to open the door panel up to manually force-shut the window for the night (no dealerships around me were open at the time and the car parks outside over night).
    Happened to me @ 29K. Replaced by a reputable dealership under warranty. Took 1.5 hours total.
    08 Audi A5 s-line 6MT - new daily
    06 Audi S4 6MT - JHM'ed :)
    01 Porsche 911 Turbo 6MT - some mods ;)
    06 Scion Xa - road trip monster
    Senior Member Two Rings dannyvox's Avatar
    Mar 25 2008
    new york
    happens to me all the time with the driver window as well as the back right
    sometimes it works and sometimes not
    its a pain
