Results 1 to 11 of 11
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Question B6ers with factory ride height
    does anyone have a factory height b6? or know the answer to my question...
    how many inches is it from the ground to the top of the front and rear wheel wells? ...not the actual well, but the fender opening right where it folds inward
    im looking for dimensions on both sport and standard models.
    i bought my A4 a few weeks ago, and the previous owner lowered it, im trying to figure out how much.
    Thanks
    Jan 10 2007
    VA
    Re: B6ers with factory ride height
    I know my USP was about 26 front / 25.75 rear on stock sport suspension. Non sport is about .75 higher...so probably:
    Sport: 26 front / 25.75 rear (note 02 sport is a little lower than this)
    Non Sport: 26.75 / 26.5
    Senior Member Three Rings Kengineer021.8's Avatar
    Sep 26 2006
    Whittier, CA
    2002 Sport:
    26" front / 25.5" rear
    Go: APR Stage 2, TT 225's, Forge 007 DV, STaSIS SS, RS4 Rear Sway, RaceTec FMIC, Forge TIP
    Show: 19" GM VMR 708's, Delsa S4 Spoiler, Blacked Out Grilles, Tint, Smoked Side Markers, De-Badged, RS4 Engine Cover, Aero Wipers, RNS-E, CC, Tinted Tails
    May 30 2008
    Honda HRX
    Penna.
    thanks for the quick reply...
    currently i sit at 24 7/8" front and 25 1/8" rear
    it looks killer, but it rides like crap ...i hit the snubbers often and thats also trying to avoid potholes
    May 30 2008
    Honda HRX
    Penna.
    Looks like they are H&R sport springs... the coils are red, and the height is right
    "Lowers: approximately 1.7" Front, 1.6" Rear for quattro" -AWE Tuning
    ok next question... would going from these to Eibach "Pro-Kit" (1.2 / 1.2)springs do alot for driveability?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    EIbach pro-kit is pretty much stock sport suspension. I wouldn't make that move but it will help driveability
    Veteran Member Three Rings plug1's Avatar
    Mar 31 2008
    Colorado Springs
    What shocks are on it? If it rides like crap and you're sure there are aftermarket springs installed, the previous owner could have put the springs on there without replacing the shocks causing the bad ride quality.
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Get some coilovers. My old car had the eibach kit on it and it had a shitty ride too. My Audi has KW V2s and the ride is amazing. Its nice and low but still comfy
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Sep 26 2006
    Whittier, CA
    Or you could just buy my '02 sport suspension setup (shocks/springs/rear sway bar)...
    Shameless plug... I know, I know.
    May 30 2008
    Honda HRX
    Penna.
    at the moment, i have no jack, or tools... we are in the process of moving, and most everything i own is packed away.
    only thing i can tell about the shocks is that they are red and black... on one of the rears i could make out "monroe" stamped into the body near the lower mount.
    the roads around here arnt the best either... i also have to go down a dirt road 1ce a week this thing has me feeling the need to swerve around the larger of the rocks... lol
    we also see about 90" of snow annually... so... =\ ...i might pick up a pos for the winter... tis a shame to put away the quattro for a junker, but it would save salt damage
    Jan 16 2007
    Wetzlar
    sounds like OE shocks.
    red OE shock = OE sport
    black OE shock = non-sport.
    non- sport springs and Koni FSD
