Originally Posted by
0000VW
The ticking at idle speeds is a combination between the injectors flowing and the valves opening (mostly hearing the valves). small ticking in our engine is normal, once it starts knocking as if it's an 94' Corsica then you should look into stepping up those oil change intervals.
Yeah, I know that some ticking sounds are normal. This sound isn't though. It can be pretty loud and just echoes sometimes....like in a drive-thru.
It is also quite noticeable when I am driving and go to press the brakes...causing the RPM's to drop immediately. It will make a loud shuttering sound. At idle it is only a tick...but its not always there.
I am pretty sure its not tensioner pulley now. I put my ear next to the motor during start up and it almost sounds as if it is coming from the rear of the motor (closer to the firewall)
Btw Emo -- I did check my power steering fluid and it is low again.
I am not sure if the that is related to this sound since it doesn't sound like its coming from that area. Maybe that is what's causing the shutter sound when RPM's drop instantly.
Who knows with this thing.
