Results 1 to 7 of 7
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    FMIC Ebay Piping.
    Guys, Im a little confused. I see some of the pre made kits reuse the stock Throttle body hose and start basically from the headlight. But I see alot of you guys get rid of it and start right at the throttle body with your piping.
    I got the 2.25 inch piping. Should I start from the TB or end of the hose?
    May 04 2004
    00 BB S4
    York, Pa
    Re: FMIC Ebay Piping.
    Thats your decision. I think it looks better but takes more work and you need to have the extra clams and couplers
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by 98a4 View Post
    Fair enough Thanks man.
    Also, Im reading that guys were having issues where the piping would blow off the turbo outlet pipe under boost. I talked to clint and he said to use clamps and glue. What do the b5 guys use?
    May 04 2004
    00 BB S4
    York, Pa
    Check the DIY Ebay FMIC thread, theres a few soloutions on there from hairspray to putting tube inside the joint and claming that
    00 S4 BB Stg3
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    If the pipes do not have a bead on it you might want to find someone that can put one where ever you need to clamp down a hose.
    Sep 24 2007
    Woodbridge, Ontario
    Sorry man, new to this. What do you mean a bead? the ridge at the end of the pipe?
    May 04 2004
    00 BB S4
    York, Pa
    Correct
    00 S4 BB Stg3
