Results 1 to 11 of 11
    Registered Member Four Rings Noffy's Avatar
    Sep 06 2007
    Audi A4 2.0T, Forester 2.5xl
    Portland Oregon
    0089 Fuel pressure regulator performance
    Just putting this in the archive for someone to find on a search some day. I through this code the other day. I can't say it was in response to anything specific I had done. I have exhaust, air filter, forge DV and RS4 rear sway bar for mods. I am not chipped.
    I email my service advisor asking if this was okay to drive through the holiday weekend. She got back to me promptly and said I should bring it in, and could I get it to the dealership that day (friday before memorial weekend). I took the car in, knowing that there is a TSB about cam lobe where I asked them to look into this if there were going to be poking around in this area.
    It turns out the TSB deals with physical wear but also the fuel pressure sensor. In my case there was no wear but the sensor had gone bad and resulted in throwing the CEL. They fixed it in a couple hours under warranty and I had a great holiday weekend. All ended well and audi took great care of me as usual. Hopefully if someone else throws this CEL and comes looking they will find this helpful.
    2005.5 A4 2.0Tq Quartz Grey
    Looking to purchase a euro car that I can learn to work on, and eventually take to the track for recreation days. What is a good car to start with?
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: 0089 Fuel pressure regulator performance
    that code sure sounds familiar. they will diagnose, find and replace faulty low fuel pressure sensor, and remove + reinstall the fuel pressure sender. covered under warranty. noffy, you must have a cool dealership if they did it for you under warranty cuz i would think that all of your mods would give them an excuse to charge ya.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Sep 06 2007
    Portland Oregon
    Quote Originally Posted by RedS-line View Post
    Well no question I have a great dealer, but I don't think I really have a lot of related mods. Exhuast and intake are really the only engine ones. Those are pretty tame as well. I don't have anything affecting boost or fuel. They did ask if I was chipped so they may have thought about going that way. But I like my warranty to much to endanger it that much for just a few more Horsepower. They have done a few other minor repairs as well and I have not had any troubles. My service advisor is really nice and does a great job of taking care of me.
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    I have had the cam lobe wear issue, pcv valve, fuel sensor, and others. This page helped me a bunch! http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    ive had this code multiple times..they did the TSB on my car a few months ago, but the CEL is coming back. and im out of warranty now..im prob just going to replace my fuel pump anyways.
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Established Member Two Rings tmqv34's Avatar
    Aug 10 2007
    LA
    I don't get it... this should be covered under the TSB... regardless of your warranty or not. Have you guys not tried to bring an audi that wasn't covered under warranty anymore, but AUDI still has to cover the expenses to change the cams
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by tmqv34 View Post
    I think you're thinking of a recall... TSB's aren't generally covered by AoA when you're out of warranty. A technical service bulletin is just a common issue noted by AoA, paired with the corresponding solution.
    Justin
    DTM S4 Sprint Blue
    Established Member Two Rings elsst3's Avatar
    May 15 2010
    b7 avant 2.0t 6sp b7 a4 2.0t 6sp & b6 avant 3.o 6 sp
    Pittsburgh, PA
    All u got to do is bitch enough to aoa and they paid a 56 hundred dollar tsb and I had 150 k miles u just no how to sweet talk and know your shit and the facts and they paid for everything but a year later I am getting the same code po0089
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    The cams Audi will replace until 120,000 miles. does not matter about a warranty they cover it if that's the problem. I got them to do it twice for me.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Oct 25 2012
    rosemeas California
    Quote Originally Posted by schirm View Post
    I have called Audi of America. They had my car checked at a local dealer but they came back telling me that it was an electrical problem. I declined services, replace the cam Fowler myself and the car worked fine for 15,000. I have the same problem again. I replaced it again but i still have the problem with the car it did not get fixed this time.
