Results 1 to 15 of 15
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    UPDATE on my electrical saga (finally I think we got it licked)...
    Well the car is running and most of the electrical is done. I will continue to work on it but other things need to be done. We might still clean up the electrics but that would be next winter only. For now I'll call it 98% done and live with it for the summer months.
    It is unbelievable how much electronics there is in this car. We had to change the set up to my temporary dash because even the darn emergency flashers are electronic and would not work! I had to buy a more normal VW switch with a built in relay to get my for way flashers to work.
    Additionally we found out that everything in or on the steering wheel is also electronic. My plan was to keep the windshield wipers and the washer unit operating through the OEM stalk, same thing with the regular L+R flashers including the high beams but no they have built in electronics and circuit boards in them too and need an electronic power box that we decided to remove. Same thing with the steering wheel angle sensor, that's now out and that also affected the ABS system which I can no longer use. We tried to bypass the steering wheel sensor to get the ABS to work but I decided we had spent enough time and money trying to do so when in a couple of weeks I'm going to completely remove the ABS system in the remake of the brake system of the car when we install the rear BBK.
    So here is what is left of the electrical system (fuse box/fuses and relays) on my car. We moved things around to make it more compact.
    Here the driver’s side where most of the OEM electrical system is stationed. Now all that’s left is a few relays and fuses with some power for the horn, the new cluster and IIRC the fuel pump. You can also see at bottom left some plugs that are not used at this time. These all go to the front into the engine bay via the left fender. Some go to the ABS system.
    Different angle of the driver’s side… Pretty big clean up!
    Now a lot of relays and fuses were move to the passenger’s side. Most of these are for the ECU. This side still needs to be cleaned up but I have to wait and see how the OEM dash and perhaps a new centre console will work together to cut and finally hide the wires.
    Here’s how it looks from the driver’s door.
    Here’s the latest (temporary) dash with it switches.
    Here’s what we took out. I have not weighed it yet. Box #1 is about 12 inches high by about 20 inches wide and deep.
    Box #2 is slightly smaller.
    Dec 06 2007
    Re: UPDATE on my electrical saga (finally I think we got it licked)...
    WOW!!!!! so are u gettin new pedals as a whole unit??
    -Kirk
    BetaAlphaTau Member #58
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by AudiA4Turbo22 View Post
    Yes these are going in...
    Jun 30 2007
    Raleigh, NC
    after you figure out how much all that crap that you took out weighs, you should sell that stuff off. i hear you can get a pretty penny for copper.... friend of mine got to help demolish a house - and he kept ALL the wire that they stripped from the walls, stripped it, and sold it for stupid amount like 5 grand
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    damn! that's gotta be like 50lbs of wire!
    and im WAY jealous of that pedal setup! want something like that sooo bad. our gas pedal's position SUCKS
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Dec 19 2007
    York, PA
    damn man, you ARE crazy
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by B6Lovin View Post
    True story. Especially right now. It's like 30% more for that shit, than it was like 5 years ago. Just watched it on the news.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    awesome
    Some fast things and some slow things
    ~Josh~
    Marin, Ca
    So great man... I can't wait to see this thing in action. What does the Wife think so far?? LOL.
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    nearly speechless yet again.
    very cool.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    When I worked for a network/phone cabling company last summer we would sell all our scrap CAT5&6 cable to a junkyard place and they where paying $1.93/lb for copper even with all the insulation still on the cable! They where saying scrap theives are becoming a huge problem with the rising costs.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Jan 16 2007
    Wetzlar
    this is not a street car any more.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by a2gtinut View Post
    howd you come to that conclusion?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    did you ever get the weight of those boxes?
    -Sami-
    Jun 17 2004
    Montreal, Canada.
    Not yet, maybe this week.
