Originally Posted by
belinko
OK, I'd like to get some opinions on some BBK's for track, autocross and daily driving.
Any pros or cons to any of the following options or added benifits, such as ease of use/swapping pads, maintenance, etc. Also note I'd be upgrading the rears as well.
Alcon's, Brembo's, AP racing, Stop Tech, Willwood, BAER, etc.
I'd like to hear/read some justification for a particular brand vs the other.
TIA
We've had great success with STaSIS/Alcon (as well as Brembo). We like how STaSIS' kits are uniquely tailored to Audi's by an Audi race team.
STaSIS/Alcon brake attributes
-F1 derived calipers and rotors, using the most recent and advanced technology found in motorsports today.
-These same Alcon components are used by the top race teams worldwide; touring car, LeMans, NASCAR, WRC, etc. "Other" components are used on few SCCA World Challenge cars, however, these teams are PAID to run the kits on their vehicles.
CALIPERS
-Alcon Monobloc calipers--1pc. There is no bridge like other many calipers have which translates into maximum strength and rigidity, less flex, excellent pedal feel and repeatability.
-Very trick beveled edge (ultra-high resilience) piston seals minimize piston retraction distance, again offering excellent pedal feel. (Other's have a single seal which can melt after a hard track day. Other's pedal feel is more on/off since their tolerances aren't as close).
-Differential piston bores balance the pad force and temperature gradient resulting in better clamping force and longer pad life.
-Made in England, the center of the motorsport world (Other's components are made overseas in Asia---quality is not as high, which can result in a leaky caliper---we see numerous local clients with this issue all the time).
ROTORS
- High nickel content (optimizes pad-rotor interface so less chance of pad deposits/”warping” sensation) (Other's rotor metallurgy is poorer which results in a less porous rotor and one more liable to produce pad deposits/“warping” sensation).
-Alcon's proprietary casting and machining processes produce consistent, tight tolerances, ensuring repeatable performance.
-Patented crescent-shaped segmented slots eliminate pedal feel pulsations, increase grip and enhance gas relief (yes, cross-drilled rotors will crack over time).
-252 vane full floating, race quality rotor has a revolutionary vane design that moves 14% more air than conventional rotors resulting in superior cooling performance. This rotor also has a thinner annulus (height from inside edge of rotor where rotor-hat meet to outside edge) which translates into a rotor ideal for intense braking that is lightweight and extremely durable, offers better wear, and is more reliable(less prone to cracking/heat fatigue) since there is less temperature difference across it.
-Alcon rotors are heat treated twice so they're more thermally stable.
-Narrower setup(more compact, tighter tolerances) for better fit with more wheels.
Let us know if we can help at all.
