Results 1 to 10 of 10
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    lltek rslook bumper install.
    i got a rslook bumper but i do not have the mounting hardware or glue.
    and i for some reason audizine doesn't have a search link anymore. does any one have any info on how to install it or where to get the mounting hardware?
    thanks.
    why didn't i buy a rs4 gill when they were $60
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: lltek rslook bumper install.
    you know I just went to search, went to click where it normally is and was like wtf? there is no search!! where did it go?.. But besides that, i don't know your answer, someone does though.
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    off topic already where is the search button???????????
    and cant you just use the old bumper support with it??
    Jan 26 2007
    Saint Paul
    well yeah but dont i need to glue it? is there a install guide somewhere?
    Feb 28 2007
    04 a4 USP ; ATS
    personally, if I was you. I would just use a couple zip ties. But this is coming from someone who takes there bumper off a lot. There is no special glue that I know of, I would just try to use some really strong epoxy of some sort. It is just the cover, it doesn't take much to hold it in place.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    This stuff should do the trick
    Link
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Jan 26 2007
    Saint Paul
    thanks ill look in to that and when i am done with the bumper i can seal up any leeks.
    UK London
    Quote Originally Posted by dmaize View Post
    LOL
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    SEARCH works good right now from HotLanta.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Dec 08 2006
    Cincinnati
    You don't really want to glue the bumer cover on do you? Won't that make removing it a huge PITA? My rieger RS4 front is held on by 3 screws on each side. One of them goes from top of bumper (kinda inside wheel well), up into the sheet metal right by the turn signal. Other two screws (per side) go through the bumper, into the wheel well liner. ALL of these screws are inside the wheel.
    Just a thought... yours may be entirely different though...
