Results 1 to 8 of 8
Thread: Hid Bulbs
    Jan 08 2008
    Hid Bulbs
    My left headlight kept going out, and then would work again so I called up the stealership and he said it sounded like the igniter was faulty - under warranty he said. Then when i took it in he said the bulb was faulty, and GOD DAMN i had to pay 468 dollars to have my BULB CHANGED.
    My question is, how does a bulb go out and then come back on?? Doesn't it sound like there is a loose connection or something? And is it even normal for a car with 43 K miles to have to have a xenon bulb replaced? My dad's car has 133K miles and the bulbs all work fine.
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    Re: Hid Bulbs
    stealership...
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Registered Member Two Rings
    May 15 2008
    Miami, FL
    Re: Hid Bulbs
    whats going on man. we see that alot at my dealer. we change bulbs on car's with less that 5k sometimes. don't know what it is w/ the bulbs but some will last forever. i've also seen the HID bulbs do that. not quite sure what causes it but it seems like there's something wrong with the bulb and it cause's the igniter to heat up and shut down till it cools back off. kinda weird but i've seen it 10 plus times so i guess you just got a not so good bulb.
    Jan 08 2008
    Re: Hid Bulbs
    that sucks, i had to pay 250 for a bulb at the stealership too, if i woulda known i would have just bought some nicer 6000K ones from HIDconcept or something.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Re: Hid Bulbs
    You could have had upgraded to Osram 6000k bulbs for like $150 each.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: Hid Bulbs
    Quote Originally Posted by CHR1SXD View Post
    stealership...
    +1000
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Re: Hid Bulbs
    You must be crazy and obviously didn't look into the classfieds:
    http://www.audizine.com/forum/showthread.php?t=210971
    I am selling 2 NEW OEM bulbs for $110 shipped.
    I really really don't want to threadjack but I cannot believe that somebody seriously spends so much money on two xenon bulbs.
    -Jens
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Veteran Member Three Rings ringmaster2.0's Avatar
    Nov 05 2006
    phila
    Re: Hid Bulbs
    what is the bulb size? Looking at a philips hid bulbs, cause i am having the same problem and i want to go 6000K?
