Okay, so I finally downloaded this version, and ran as Administrator. Here is what I got. I just changed all 4 spark plugs, all 4 coil packs, and replaced the cat with a test pipe and did the spark plug fouler mod...
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 63351
8 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 008 - Please Register/Activate - Intermittent
16685 - Shareware Version. To Decode all DTCs
P0301 - 001 - Please Register/Activate - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16686 - Shareware Version. To Decode all DTCs
P0302 - 008 - Please Register/Activate - Intermittent
17544 - Shareware Version. To Decode all DTCs
P1136 - 001 - Please Register/Activate
16891 - Idle Control System RPM Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 002 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Any input from the Vag-com and Audi gurus?
edit: I think most of these are from before I changed everything out. How do I tell what's making the check engine light come on now?
