Results 1 to 8 of 8
    Jan 22 2006
    nguyen
    Stage 3+ Drag Results
    I was consistently running 1.85 60', 120.5 traps. This is with 104 Sunoco Race Gas. I ran the pump file and added 7.5 degrees with Lemmi. All season tires with full pressure 30-40 psi.
    Temp: 65F
    Relative Humidity: 0
    Absolute Barometer: 31.41
    About sea level track
    My best run for the day was:
    R/T .177
    60' 1.869
    330 5.196
    1/8 7.852
    MPH 94.79
    1000 10.120
    1/4 12.004
    MPH 120.91
    Feedback, critiques?
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Re: Stage 3+ Drag Results
    Pretty darn good for a full weight car. What's the details on your fueling setup?
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Jan 22 2006
    nguyen
    PJK04s
    AWE ICs
    AWE DPs/ Test Pipes
    AWE Twin2
    AWE Exhaust Manifolds
    GG Injectors
    RS4 Intake, Accordian Hose
    Hint on Fueling - 90mm MAF
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    Damn, that is pretty quick. Wish the V-8 could hit those numbers with out being stupid expensive.
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Registered Member Two Rings
    Mar 12 2008
    2003 A6 2.7T tip
    Salem, OR
    Was this at PIR or Woodburn? We should have a gtg at one of the drag strips sometime soon.
    Great times man,
    2003 A6 2.7T Tip, GIAC X, Piggies, Custom Exhaust, Forge DV's, 19x8 Konig Extra, 245/35ZR19 General UHP's, Tint, Custom Subs,
    Mar 23 2008
    seattle
    awesome times. Makes me happy about going stage 3 soon. What kinda wheels tire sizes are you running? Any pics of your car? What are you using for software?
    Active Member Four Rings
    Oct 12 2006
    2000 Nogaro S4
    Hillsboro OR
    his car is basically the shit :) HAHHAHAH for real...everythign you could want to do to a s4!
    12 sec is great full weight and everything. now emtpy the car, and go for some runs!
    hows you clutch doing? im afraid of going just because i figure ill burn up a clutch.
    2002 A4 - sold
    1990 CQ - sold (sadly)
    2000 S4 - sold (sadly-er)
    currently audiless
    Jul 18 2007
    West Coast
    Quote Originally Posted by knguyen View Post
    Temp: 65F
    R/T .177
    60' 1.869
    330 5.196
    1/8 7.852
    MPH 94.79
    1000 10.120
    1/4 12.004
    MPH 120.91
    In my opinion, your launching/shifting needs improvement. You should be able to run mid 11's with that kind of trap.
