Results 1 to 12 of 12
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Snow Performance Water Meth Kit
    I have a fmic and am wondering if it is safe to drill into the piping ,my main concern is boost leaks ...
    Has anyone installed this kit before ,If so what were the main issues with it?
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: Snow Performance Water Meth Kit
    i just tapped my nozzle into the silicone coupler that connects my intercooler hardpipe to the throttlebody. much easier to do. and much better seal
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Active Member Two Rings Kerr's Avatar
    May 22 2008
    2004 A4
    FL
    You can drill into the intercooler piping, but the problem with that is the piping is thin. The best thing to do is take it to a shop or welder and have a small piece of metal welded in the location you want the nozzle. This will give it more bite.
    That is a very popular company and only issues I ever hear, but this is with any kit, are pump failure, clogs, leaking connections. If you keep an eye on these things you shouldn't have any issues.
    I also highly recommend a fail safe, I believe they offer one.
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by Kerr View Post
    best wmi advice EVAR.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    May 22 2008
    2004 A4
    FL
    What's "wmi"?
    Dec 13 2006
    02 Audi A4 1.8Tqm, 95 VW Golf
    Water/Meth Injection
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    snow sells a bung that you can weld to your IC piping
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    I had no problem threading the nozzle in my intercooler piping. If you have steel piping though it is a bad idea because it is gonna rust over time and cause a hole to form in the piping, so in this case you need to have an aluminum or stainless pipe made to put the nozzle in. And the snow performance kit (the kit I have) has cheap connections which will leak. I actually need to go and fix mine now since I havent been running the kit for like 6 months due to a bad leak and the tank going empty in a day. Best thing to do is to buy brass fittings and get the crush washer/nut deal that seal the hose to replace the plastic fittings with the quick connects on them. Because they will leak I promise you that. I think A4ringedone8t had his leak in like 1 week.
    What modifications do you have?
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Sep 17 2006
    SLC, UT
    haha^
    who makes FMIC pipes out of steel?
    Current:
    Previous:
    Apr 24 2005
    E55 AMG, CTS-V
    The eurocode kit. It is perfectly fine if you dont run water/methanol in it.
    ~David~
    CTS-V 9.6@148
    Nov 06 2007
    B5 S4
    Houston
    Quote Originally Posted by A4 TSCHUSS View Post
    genesis 380's,ecode fmic,milltek catback ,ecode testpipe, revo stg 2
    Apr 24 2005
    E55 AMG, CTS-V
    You need to get an SPS 3 or Select Plus controller (I prefere SPS 3) so you can increase timing if you dont already have one. You could also just find lemmiwinks to download and add a few degrees of timing once you get the meth injection going and tuned right. I forget the nozzle sizes but I use the 375cc nozzle with full pump pressure with my GTRS so you will need the smaller nozzle below that. Then you will set your controller to turn initial spray at the lowest setting (think it is 8psi) then full spray at like 13psi range with the K03. I would go from there and then tinker with the full spray setting turning it up and down slightly to feel if the car wants to go faster or bog down.
    ~David~
    CTS-V 9.6@148
