Results 1 to 14 of 14
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Got the Vogtland GT's halfway on...
    Only had enough time last night to get the fronts on. My buddy who owns the shop had something come up so we'll finish the rest this evening.
    So driving home last night and to/from work this morning I was expecting it to feel weird but I wasn't expecting the noises.
    -Lots of clunky sounding noises with any bumps
    -No play in the steering so I'm pretty confident that everything is tightened correcty
    -Also we set the front two spring perches equal with 4 2/5" of thread showing on both passenger and driver side but when we put the car on the ground the driver side is obviously lower. (not something that can't be adjusted, but why???)
    I have noticed that the inner fender (which are being rolled on Mon.) have been slightly rubbing since last night...could this be the noise I'm hearing??
    Any help would be appreciated, thanks
    GIAC Flashed ECU++++FORGE 007 DV's++++ECS 2 piece Front and Rear Rotors++++SS lines++++VOGTLAND GT's
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Re: Got the Vogtland GT's halfway on...
    Its possible the clunking came from the top bolt that wasnt tighten. As for the uneven height, I would check if the perch moved when you were moving the car down.
    Dec 14 2007
    Motorcycles
    Bainbridge, NY
    did you torque all the control arm bolts with the weight of the the car on the suspension (as if the car was sitting on the ground). If you didnt, that could cause binding and uneven ride height.
    fwiw, when i did mine (properly) i got within a 1/16" of an inch side to side on front and rear by setting the height to the values he has on the startup racing page. That also happened to be the "perfect" ride height as far as i'm concerned. (probably a little higher than most here would like)
    as far as the clunking... something must still be loose.
    did you use all new control arms? difference in Control arm wear from side to side could also the unevenness (because they act as tiny little torsion bars because of the bushings)
    B6 Avant 1.8TQM - 2871RS beater. I am not a smart man.
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    I didn't use new control arms, but the bushings looked decent and have NEVER made any noise before.
    Nothing was torqued down after the car was put on the ground, perhaps that's the mistake, something's definately loose.
    I will report back to this thread after this evening and we get it all done.
    P.S. Now that I think of it, how would one have any room to get under the car to torque anything down once it's on its wheels?
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Also, just for referance, I just measured the fenders. Pass-25.9", Dri-25.0"
    Tomasz suggests 4.5" of thread left on the strut, I went with 0.1" lower. Anyway, I will post more when I have more info and the answere to what's going on.
    Thanks for your reply's!
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    You shouldn't have any clunking. Like mentioned earlier, the top nut on the shock bushing is more than likely not tightened properly. An impact gun is not the proper way to tighten it.
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    It was the top bolts of the struts as suggested, thanks.
    Got them all done today and they feel GREAT!!! Whole differant car for sure.
    Still have issues with uneven ride height.
    Am I supoesed to use the stock rubber perch bushing in the fronts??
    (modified them to fit the new springs)
    Corner balancing tomorrow morning for perfect height
    (I'm right at 25.4" in front) but the rears are at about 26.3". Want em down under 26"
    so far no rubbing issues in front even under hard cornering)
    Thanks for everyone's reply's!
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    hey, how do they handle bumps?
    l gotta-- l gotta get
    a form from a scientist.
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Got the corner balancing done this morning. Front fenders are at 25", rears are at 25.25"
    Honestly, it feels like it eats the bumps better than stock. There's no cringing when aproaching uneven road, that's for sure.
    These handle extremely well, very happy with my purchase. I will post pics after I wash it this weekend.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Can't wait to get my GT's on. Just need to find out which control arms I need to replace.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    have you put the rears on yet?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Quote Originally Posted by j_korteS4 View Post
    Sure did, can't corner balance with stock suspension.
    The rears go on like butter.
    Jul 19 2007
    San Diego, CA
    The spring sits directly on the plastic ring, which sits directly on top of the adjusting perches.
    On top of the spring will sit a rubber packing part, then the aluminum control arm frame.
    There is NO rubber on the bottom of the spring.
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Quote Originally Posted by Mike@PureMS View Post
    Hmm...
    That's exactly how the rears are, but the fronts for some reason did not come with that plastic ring. So instead of them sitting directly on the perches, I used the stock rubber piece and ground it down to fit the new spring.
    Was this kit suposed to include the two plastic rings for the fronts??
    Thanks again
