I remember seeing a post here a while back with questions about boost guages. Here's a cross-post from AW's allroad forum where I posted my tips/experience:
First, here's where the $80 ProSport gauge is mounted. All you need to do is pop the vent out at the front and drill a 3/8" hole at the back of the vent location to run the wires. Note that the ProSport gauge includes the mounting cup, visor and double-sided tape that you'll need to mimic my install.
Under the hood, you just need to tap into a boost/vacuum line using the supplied tee and vacuum hose. I chose to tap into the fuel sender module's line (some discussion on if this is the best line to tap, but it's the easiest to find, snip and insert the tee). I also ran the hose into the battery compartment and mounted the control module/sender for the boost gauge to the ECU box to keep it cool and dry. There's a nice grommet you can use to get into the battery compartment, and another nice little grommet/plug leading into the firewall just to the right of the battery.
Here's the details under the hood:
Other than that it's pretty simple -- just follow the instructions that came with the gauge (they're hacked up English from China, and a bit cryptic): Red goes to battery lead, black to ground, white/orange go to switched source and/or light switch (the gauge can change color when you turn on your lights -- handy as the white gauge face is pretty bright at night).
Other tips: Run the wiring from the firewall into the cabin by completely removing the triangle-shaped plug and using a coat-hanger wire to fish the wire down to where you can reach it. Same goes for the access from the vent pocket to the fuse box next to the driver's side door.
And one final word of caution -- make sure you use new boost line hose where you tap into the line -- when I tapped it the first time I ended up making a small hole in the line, and it caused the car to go into limp mode and run lean b/c the fuel sender wasn't getting the right amount of boost to adjust correctly. It may be better to tap into the line under the Y-Pipe, the only drawback there being that you have to remove the pipe to get to the line.
There you go! Easy-peasy :-)
