Results 1 to 36 of 36
    Veteran Member Three Rings Outkasted's Avatar
    Feb 12 2004
    01 986 Boxster/ Unrestricted Hayabusa
    independent fog lights
    I want to do the independent foglight mod but i am not sure what he is talking about cutting in the diy on audiworld. Does anyone know of a write up with pictures. This would be for an 02 s4.
    Thanks
    Always looking for the next project
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: independent fog lights
    Quote Originally Posted by Outkasted View Post
    Thanks
    I would show you but my car is getting fixed up right now.
    You take the black box out. Then you look at the multiple 'teeth' sticking out of the top. You 'chop' the 2 numbers completely off (i think 15 and 17, but don't quote me on that) and then solder the base of those chops of teeth onto number 12 with a wire (again don't quote me on the numbers).
    Simple, and if you have a solder, takes 5 minutes tops.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    is that the black box in front of the glove box? I tried to get at this a while back, but my man hands couldnt fit back there to get access to it
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    yeah take the glove box out and the little side pannel. it is a major pain in the ass to get to, i used a long flathead to help me pry it out. once you get that out you'll see all the prongs on it. pretty straight forward from there with the DIY.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Feb 12 2004
    ok so you chop of the prongs on the black box according to the diy. Then you solder a wire from the chopped points to the other according to the diy. Ok now i get it. I thought the entire thing was suppose to come out and all i could get out was the black box. Thanks for the clarification.
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    follow the AW writeup. Whats so hard to understand about that?
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Feb 12 2004
    i was reading the AW write up and was a bit confused because it seems like both the box and the peice it plugs into are suppose to come out and i couldn't make that happen. If you bothered to read my first post NY02s4 you would know that i was trying to follow the aw write up. With that said was your post necessary?
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    The black "box", ( its a relay), is sometimes very hard to remove. I had to pry mine up with a flat tip screwdriver.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Funny, mine was really easy to take out (maybe I have small girly hands?) but a big pita to put back in the harness.
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Anyone with basic mechanical skills should be able to remove the relay box. It can be a huge PITA if you have big hands and or not used to working in those types of situations in a car.
    make sure you go to the S4,A4 writeups and look for:
    "Control Fog Lights Independently from Headlights and Rear Foglight by: Peter Harren 2000"
    http://www.audiworld.com/tech/ext.html
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Ok. I am bringing this thread back to life. I need some info from anyone who has done this.
    I cut pins 12, 15 & 17. Soldered a wire from 14 to 15 to 17. Nothing, no fogs.
    I probably need to do a better soldering job.
    Input please!!!
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    You need to do a better soldering job. Everything you described is correct.
    Innovate.
    Jul 13 2008
    figured it out.
    ...and if you don't like my bulb color temp u can go fuck yourself
    Registered Member Two Rings
    May 17 2009
    Virginia Beach, VA
    Actually, I do like the color temp.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    Quote Originally Posted by Karl View Post
    x2 does it match the headlights? what bulbs?
    Jul 13 2008
    no, headlights are 6000k. I went crazy and tried 12000k, may switch to 3000k when i get bored of it
    May 17 2009
    Virginia Beach, VA
    Okay, so you did an HID upgrade in your fog lights then did the independent fog light control mod, is that correct? If so, what kit did you use to upgrade the fogs to HID and how was the install? I'm considering this myself..
    May 06 2009
    01S4, looking for a second
    indy
    I've been thinking about this mod since the ktits were 400 on ebay. Now that they are 100 from legit sources.. I'm closer and closer every day.
    Jul 13 2008
    http://www.vvme.com/
    used these guys, very cheap price but quality parts.
    search HID fogs on the search button, there is a DIY and i used my own cottering pins and secured the bulb to the fog housing. Plug and play baby.
    Feb 27 2007
    Chicago
    you don't need to add the wire. You can just throw down a slab of solder connecting the three spots. It is a lot easier to remove the glove box holder to put the relay back in.
    97 A4 2.7T OEM RS4 Widebody 6-speed
    01 S4 2.7T Imola Avant 6-speed (Sold)
    90 Coupe Quatrro 20v (Sold)
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    I might do this tonight. Thanks guys.
    Jul 13 2008
    yep, a glob of solder is all it took to get it right. The chip is so damn small any size wire seems too big to solder on.
    Glob it up
    I like this mod because basically I have driving lights whenever i want, no need for headlights until its completely dark
    Apr 17 2007
    B8 A5
    Are the rear fog lights independent now too?
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by tike0rz View Post
    Independent to the headlights but not the front fog lights.
    Senior Member Three Rings puz84's Avatar
    Jul 30 2009
    97 eclipse GS
    Boston
    im going to revive this thread for the second time rather than making a new one.
    My main concern is reliability since your essentially jumping the circuit, has anyone went back to their relay module and check on the circuit itself to find any signs of wear. Some people have told me that this might be quite dangerous by starting a fire.
    After all the research I did, i still went about with the diy maybe due to a taste of desperation and lack of time, :).
    I must say, this is my favorite diy mod so far.
    Any input is greatly appreciated.
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by puz84 View Post
    Agreed this is one of the best DIY mods available. I did it about 2 weeks ago and no issues so far, and I haven't heard anyone having a problem with it either. So it seems to be safe...
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    Would be nice to get the rears independent too, for fake brake checks when people are tailgating, I used to do that all the time in my B7 A4 never failed and I laughed my ass off every time. Would be cool with the LED headlights to get those independent as well.
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by TWiST View Post
    Well all you have to do is throw the front fogs on to get the rears to work. And you can do all that with the lights off so in a sense the rears are independent.
    Jul 30 2009
    97 eclipse GS
    Boston
    I always have my front fogs on, so the rear fog is never a problem to switch on for me.
    Anyone do this diy project a while back and have any expertise on this small concern?
    Senior Member Three Rings thegame's Avatar
    Jul 09 2009
    norcal
    I agree. It seems like there's a less messy way, probably cutting the wires coming from the foglight switch, or the wires directly from the relay.
    Mar 11 2007
    8V S3
    tri state
    This is actually the least messiest way. You can easily replace the relay module or remove the wire. I'd much rather do this than tap into the hard wiring in the harness.
    Besides, there hasn't been anyone to report a problem yet. I actually did the pure solder connection and I haven't had an issue.
    Veteran Member Four Rings BlackLock_A4's Avatar
    Sep 14 2009
    San Jose
    Cant you just hook a vag-com up to it and do it electronically? That's how I always thought people did it.
    2001 1.8TQM
    Speed doesn't kill. It's that damn sudden stop.
    Veteran Member Three Rings wesS4's Avatar
    Nov 29 2007
    1966 Mustang
    San Jose, CA
    Quote Originally Posted by BlackLock_A4 View Post
    Not on a B5
    Stage 2 B5 A4 Avant | AWE | GIAC | H&R | OEM+ | BBS | Raven MS | 034 | DDM
    The Auto Shop
    TEAM|AXION is dead. RIP LOL
    Apr 17 2007
    B8 A5
    To my passengers, I call the rear fogs the asshole lights. Well, they're tailgating me, that asshole. Heres a light for you. Fake brake checks ftmfw.
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    This is what I'm doing. I''m going to splice the LED wires to the fog lights and make the fogs independent, and eventually either HID or LED to match the LED's in my headlights.
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Jul 13 2008
    ^pic of the LED headlights on your ride plz?
