Originally Posted by
SilverQuattroA4
When I press any of the buttons I does not light up (the led) But the buttons themselves are lit up.
It would be interesting to know where the module is so I can check if it is plugged.
Exactly how mine was. The plug should be located behind the front bumper. My guess is that the plug is simply not together tight enough for contact with the transponder.
Don't realy remember where the plug is. My local shop had it all apart to do my timing belt. They were able to go back and fix the plug without the need to take the bumper off (might be accessible between the bumper and the radiator?).
If the plug turns out to be securely connected, then the fault may be with the transponder (expensive to replace).
