Results 1 to 8 of 8
Thread: Rotor turning
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Rotor turning
    Hey guys and gals just a quickie, I called a shop, the guy said he doesn't do it but he also said that he does not recommend turning the rotors... I have B5 S4 rotors but he had a strong accent so I didn't quite understand but he said it would ruin them or what not.
    Any merit to this?
    If there is can someone point me to a discussion on how to seat my new pads properly? I don't want to waste these nice Hawk pads.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: Rotor turning
    I got turned down before too. Something about our rotors are not meant to be cut, they are supposed to be used and replaced because the thickness after they have been used a while doesn't leave much to cut off
    Aug 14 2007
    Ottawa, ON, CA
    Re: Rotor turning
    Can anyone tell me the min thickness for an B5 S4 rotor? I don't have the bentley for that year
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Rotor turning
    I've had my B5 S4 front rotors turned twice now. So far so good.
    Not sure on the min thickness requirement. Might want to check the Bentley for a B5 S4.
    -Doug
    Aug 14 2007
    Ottawa, ON, CA
    Re: Rotor turning
    After looking around I think it says it on the rotor itself, I believe it's 24mm. I have some pretty good lips on mine, so I'm thinking I might need new ones. Everything I have seen now says that those things are meant to be replaced not turned. Germans like to replace things apparently :P
    Buncha motorcycles
    Memphis, TN
    Re: Rotor turning
    i know a4 rotors arent very expensive, adam@ssp has some good deals and you can find some brembo blanks on ebay (yeah yeah i dont usually advise buying audi stuff on ebay) id replace them for a few hundred bucks and be done with it.. i "heard" somewhere that OEM audi rotors are softer metal or something..
    APR Stage 2/AWE Intake
    Aug 14 2007
    Ottawa, ON, CA
    Re: Rotor turning
    Done deal, just picked up a pair of Zimmerman rotors for $200
    Thanks for the help everyone
    Mar 11 2008
    B7RS4 & e46Ms
    Re: Rotor turning
    Quote Originally Posted by Casius View Post
    Seek, read, learn...
    http://www.stoptech.com/tech_info/wp...rakedisk.shtml
