Results 1 to 8 of 8
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Stripped Trasmission Fill Plug HELP
    So yeah, good I didnt dump the oil before I stripped the fill plug... Now, my question is, how do I get it out? What happened was the allen wrench didnt go all the way in... it only went about a quarter of an inch in when it should really have gone about a half inch. So, now the beginning of the allen hole is rounded.. Down deeper it is still hexogonal but the thing is, now since the start of the allen hole is screwed up it doesnt go down any deeper to catch the good part. I tried pounding it in but the more I do the more burr it creates inside and it just makes the situation worse..
    Any ideas????? I am going nuts here.
    Thanks
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings W1CK3D's Avatar
    Sep 19 2006
    Just my S
    North 'burbs (Chicago)
    Re: Stripped Trasmission Fill Plug HELP
    Dremel a flat in, or just keep pounding until you get a solid hold on the plug and replace the plug gets my vote-
    Current: 2002 Nogaro B5S4
    Gone: 2006 Dolphin Grey B7S4
    Gone: 2000 Nogaro B5S4
    Dec 06 2007
    Calgary, AB, Canada
    Keep pounding and then replace the plug
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    if all else fails remove the speed sensor and fill it thru there :P
    Feb 22 2007
    Earth
    I have already tried pounding... it makes matters worse plus I am at a point where it feels like every time I give it a hammer shot it feels like a dead blow..... Now, I havent stripped it completely but it started to so I stopped wrenching it. If I put some PB blaster do you guys think it will eventually soak in? Cause that thing was on tight!
    It also seems like the rotor is in the way if I wanna go out to a more open space to do the hammering.. I think hammering the shit of out it would work If I got the break assembly off but I have never done that. What are the steps involved in removing the breaks.. Is there a writeup?
    Dec 06 2007
    Calgary, AB, Canada
    The calipers are pretty easy to get off. There are some writeups floating arount on AW.
    Feb 22 2007
    Earth
    I got the Plug out! Now I am waiting for a new one... I used a torx bit of the same size and that was able to go all the way in... now the weird thing is that when I called audi they said that the fill plug and the drain plug are 2 different part numbers... but from the outside they look the same... hmmmm, weird
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    did you look at the threads maybe the pitch is different ? mine came out easy thankfully good look
