Results 1 to 6 of 6
    Senior Member Three Rings jlien08's Avatar
    Jun 28 2007
    98.5 A4 1.8TQT, 01 ZR2 Blazer
    Woodbury, MN
    Alright guys, need some help with some codes
    edit: So I seem to be in limp mode. I can start the car, it runs, although the rpm's bounce just a little bit. I need to get this thing back on the road!
    This is my most current VAG reading. I know my problem is related to the CPS code (P1338), but I can't seem to figure out what the hell is wrong. The only thing I can figure is that my timing may be off. All I had done is replaced my valve cover gasket and the little gasket that goes under the Timing chain tensioner. I have a feeling my problem may liew with the tensioner and not the CPS, as I have tried two different ones, and neither made a difference. This is what I'm getting, any help would be greatly appreciated!!
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Wednesday,28,May,2008,22:26:22:44613
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 274780km/170740miles
    Address 01: Engine Labels: 8D0-907-559-AEB.LBL
    Part No: 8D0 907 557 P
    Component: 1.8L R4/5VT MOTR AT D04
    Coding: 06251
    Shop #: WSC 01234
    2 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17746 - Camshaft Position Sensor (G40): Open or Short to Plus
    P1338 - 35-00 - -
    Readiness: 0010 0001
    Address 02: Auto Trans Labels: 8D0-927-156.LBL
    Part No: 8D0 927 156 BN
    Component: AG5 01V 1.8l5VT USA 8508
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-00 - Implausible Signal
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
    Part No: 8L0 820 043 D
    Component: A4 KLIMAVOLLAUTOMAT_D75
    Coding: 04142
    Shop #: WSC 01234
    5 Faults Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-10 - Implausible Signal - Intermittent
    01582 - Signal for Coolant Temperature
    Address 17: Instruments Labels: 8D0-919-xxx-17.LBL
    Part No: 8D0 919 910 P
    Component: B5-KOMBIINSTR. VDO D05
    Coding: 02242
    Shop #: WSC 00000
    No fault code found.
    Address 35: Centr. Locks Labels: 8D0-862-257.LBL
    Part No: 8L0 862 257 N
    Component: CV-Pump D06
    Coding: 16140
    Shop #: WSC 01234
    3 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    1998.5 Audi A4 1.8T Quattro Tiptronic - MagnaFlow - Bilstein - Neuspeed - EvoMS - 034MS - LLTek - FMIC - VDO -
    Dec 05 2007
    Re: Alright guys, need some help with some codes
    Here is what Ross Tech has listed:
    P1602:(possible causes)Cables on the Battery were removed
    Battery weak (voltage)
    Generator Disfunction
    (possible solutions)Check Battery Cables
    Check/Replace Battery
    Check/Replace Generator
    P1338:(posible causes)Camshaft Position Sensor (G40) faulty
    Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
    (possible solutions)Check Camshaft Adjustment
    Check Camshaft Position Sensor (G40)
    Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
    00526:(possible causes)Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
    Brake Light Switch (F) damaged
    Brake Light faulty
    Fuse(s) faulty
    (possible solutions)Check wiring and connections
    Replace Brake Light Switch (F)
    Check / Replace fuses(s)
    Check / Replace Brake Lights
    Check Brake Light Switch (F) in ABS Measuring Block
    01274:(possible causes)Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
    Positioning Air Flow Flap Positioning Motor (V71) blocked
    Positioning Air Flow Flap Positioning Motor (V71) faulty
    (possible solutions)Check Air Flow Flap Positioning Motor (V71)
    -See Measuring Value Blocks (MVB)
    -Perform Output Test
    -Perform Basic Setting
    Check/Repair Wiring and Connectors
    00604: I could not find it
    01273:(possible causes)Fresh Air Blower (V2) defective
    Control Module for Fresh Air Blower (J126) defective
    Wiring defective
    (possible solutions)Check Fresh Air Blower (V2)
    -Perform Output Test (Check Air Vents while Blower is active)
    -Check Meas. Blocks while Blower is active
    Check Control Module for Fresh Air Blower (J126)
    Check wiring
    01206:(possible causes)Ignition Switch faulty
    Wiring between Instrument Cluster (J285) and Climatronic Control (J255) faulty
    Instrument Cluster (J285) faulty
    (possible solutions)Check Ignition Switch
    Check Wiring between Instrument Cluster (J285) and Climatronic Control (J255)
    Check Instrument Cluster (J285)
    Check Climatronic Control (J255)
    01582: I could not find
    01370:(possible causes)Anti-Theft Alarm triggered by Signal from Ultrasonic Sensor Control Module (J347)
    Ultrasonic Sensor Control Module (J347) faulty
    Wiring/Connectors from/to Ultrasonic Sensor Control Module (J347) faulty
    False Alarm
    (possible solutions)Check/Clear Fault Codes
    Check Ultrasonic Sensor Control Module (J347)
    Check Wiring/Connectors from/to Ultrasonic Sensor Control Module (J347)
    01369:(possible causes)Anti-Theft Alarm triggered by unauthorized opening of Trunk Lid/Tailgate
    Trunk Lid/Tailgate Central Locking Switch (F218) faulty
    Wiring/Connectors from/to Trunk Lid/Tailgate Central Locking Switch (F218) faulty
    False Alarm
    Check Trunk Lid/Tailgate Central Locking Switch (F218)
    Check Wiring/Connectors from/to Trunk Lid/Tailgate Central Locking Switch (F218)
    00956:(possible causes)Remote control not working.
    (possible solutions)Key not matched.
    Key operated more than 200 times while out of range.
    For future referances
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Vegas
    I want to say that Power Supply issue has something to do with the speed of the windows going up and down...something minor like that. i had it, looked it up and ignored it months ago. everything has been fine since then.
    don't know much about what the cam tensioner would be, but my question is when was the last time you replaced the timing belt kit? (which includes that tensioner)
    Jun 28 2007
    Woodbury, MN
    I replaced the timing belt and all it's pulleys/tensioners in december. There aren't any problems there. The problem is with the timing CHAIN tensioner on the back of the head. That is where I ran into problems. Any help on how to get it back on track?
    Quote Originally Posted by Vegas34 View Post
    Jun 28 2007
    Woodbury, MN
    bump.
    Is it possibly to throw off the timing by moving the timing chain too much? keep in mind I never fully removed the chain from the cams...
    It throws the MIL light and the 17746 - Camshaft Position Sensor (G40): Open or Short to Plus P1338 - 35-00 - - code immediately after starting the car. I'm lucky if I can drive it out my driveway without the rpms dropping way too low and dying...
    Jun 28 2007
    Woodbury, MN
    nobody on the CPS issue?
