Results 1 to 38 of 38
    Dec 06 2007
    Decided to go GTRS Eliminator!
    IIght guys, i've driven u nuts with my threads but this is final! Ok so i can get the kit from Eurocode for like $1400 includes all the hardware, and these are additional mods i'm considering:
    I HAVE A TIPTRONIC!!!!!!!!
    -Neuspeed Xtreme tip as well as throttle body hose
    -upgraded fuel rail, from eurocode
    -FMIC/SMIC
    -High flow manifold
    -testpipe
    -redo all VAC and Boost lines
    -timing belt
    -injectors- 440cc or 550cc(which one is better?)
    -Software(REVO or what?? please tell me)
    -What are the benefits of a VR6 MAF??
    -what are the benefits of a bigger throttle body??
    -anything else??
    -Kirk
    BetaAlphaTau Member #58
    May 26 2008
    orlando
    Re: Decided to go GTRS Eliminator!
    Vr6 Maf housing is bigger, injectors depends on the hp target.....but from the turbo ill say 440cc will do it.
    Established Member Two Rings setay's Avatar
    Jan 03 2008
    Carson, CA
    you're not planning on the tranny upgrade? i know its expensive, just wondering about your thoughts on it.
    alot of the members will tell you to go with REVO. im 90% sure thats what i'll get.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    ^^^ I thought a tip was fine with 350hp crank.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Sep 07 2007
    San Francisco, CA
    Doesn't REVO have a GTRS file specifically for Tiptronics that limits the torque by limiting the boost?
    Veteran Member Three Rings audi314's Avatar
    Oct 22 2007
    06 A6 C6 Avant, 12 F-150 FX4 Twin Turbo
    ATL
    If your looking to be around 290-300 AWHP then you will need to run 550cc on the REVO BT software. VR6 MAF is not worth it, so I would advise against it. Being in Socal I would go with a FMIC.
    Why are you wanting to upgrade your fuel rail? The stock one can handle the flow requirements just fine.
    Hope this helps!
    I had a BT Audi!****> Lost at Barber MSP 11/1/09
    Hero-->http://www.youtube.com/watch?v=Q3gN6...eature=related
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    OK post whore. Let me make this simple. As long as you have the stock valve body in the tranny, you'll never see anything above 270 awhp so getting an upgraded fuel rail, VR6 MAF, etc is a waste. My suggestions:
    GTRS Eliminator turbo w/ REVO programming (550cc injector file).
    SPS 3 or SPS SELECT is a must!
    ATP manifold -- stock manifold will yield a slightly faster spool though
    Neuspeed Xtreme TIP
    K&N drop in filter
    FMIC
    Hi Flow cat as a first choice, test pipe second choice
    Electronic boost controller -- help reduces lag
    Exhaust
    Once this is done, invest in an upgraded valve body and possibly an upgraded torque converter BUT is not required unless you wanna get all of your potential power to the wheels.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Sep 20 2006
    MD
    Quote Originally Posted by grimlock View Post
    No, what limits torque to the tranny is the TCU getting a signal from the ECU once engine torque exceeds roughly 410Nm to purposely slip the tranny.
    Sep 07 2007
    San Francisco, CA
    Quote Originally Posted by RLB6 View Post
    Ah, thanks! Btw, what EBC do you specifically recommend? Would it replace the stock N75?
    Sep 20 2006
    MD
    eBoost, HKS, Greddy are all pretty good. I run the Profec B spec II and it works great. An EBC would eliminate the need for the N75.
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Way to go man!! Im stoked because I want to go down this road eventually as well. I really want to take a ride in your car once you get it running......please!!!
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Dec 06 2007
    ^^haha dude i asked in our local forums if anyone had one to gimme a ride, but ya when i'm done i'll let u take it around the block if ur a decent driver! as for RLB6, this is what i have:
    -exhaust
    -CAI
    -boost gauge
    -thats it i guess that would aid in this build
    -i really want the fuel rail just for the looks and it's like a $100 so nothing extremely steep!
    -how much is an SPS whatever it is thingy??
    -and hell no with the money that it takes to upgrade the valve body and crap i'd buy a 1988 MBZ 560SEL!
    -Kirk
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    I just had my ECU done at Eurocode. I walked in asking for REVO and they recommended APR. I've been happy with it, but don't know the alternative to compare. They are trying hard to get me to put in an Eliminator, but too much $$ for me right now.
    I did do a test pipe, myself, which was a biatch. That has been the best bang for the buck so far. My car rockets to redline, compared to the before w/ the cat. Ebay for $99 new, and they are out of OC. The quality seems as good as any high $$ ones I looked at.
    New injectors, and the stage 2 are great too. All my mods are evaluated on bang for the buck. I have been stoked on my results for the dollar so far.
    I will look forward to hearing about your Eliminator install.
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Dec 06 2007
    ^so u have a K04??? that's stage 2! do u have injectors thats a stage 1+, if neither then u have stage 1!
    -Kirk
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by clcsocal View Post
    unless you have a k04, you have stage 1+
    APR Stage 2/AWE Intake
    Mar 12 2006
    Costa Mesa
    Quote Originally Posted by AudiA4Turbo22 View Post
    -exhaust
    -CAI
    -boost gauge
    Hell you can drive as long as I can just feel what its like and what I would expect.
    I'll keep my money,
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Kirk, Congrats! You will be happy with this decision.
    My recommendation is to listen to RLB6. He has worked hard to figure out the BT set-up with an automatic trans.
    -Doug
    Dec 06 2007
    ^^this is the reason i'm going GTRS, because if i get stuck doing a k04 build no one can really help me out, but since so many people have gone GTRS and i read RLB6's build thread(he got owned lol) i saw that it was worth every penny he's spent, and well i didn't want to risk not making 200WHP with a K04 after spending $3k!!!!
    -Kirk
    Sep 20 2006
    MD
    Get your GTRS set up in and we'll worry about the rest afterwards. Oh, I need to get off this forum. I have some brakes to put on
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I guess all of the B5 TIP guys that ran BT's before B6's were even produced had nothing to do with that.
    Just odd that B5's TIP guys are running BAT's but yet the B6 guys are worried about running a BT.
    Some times I get the feeling that the B6 guys forget that there was such a thing as a B5 that came before them.
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    x2 Doug.
    Kirk.... RLB6's setup is what you should mirror.
    I'm actually going that direction too...... I'm giving up my APR 1+ and going to GTRS with REVO.
    I have a '02 Tiptronic.
    Dec 06 2007
    I DON'T WANT TO SPEND $3K ON A 2871R, my boost is gonna come in late already lets not extend it! but this is smart i think: i'm going to go with the total kit that includes everything for $2500 from eurocode, software, injectors, sps,etc. basically what my calculations came out to, just need a tip and an FMIC, and a throttle inlet and i'm set! thanx guys! please keep me up with advice!
    -Kirk
    Sep 20 2006
    MD
    Well, the B5 guys have a slightly different tranny AND have a tip chip available to them so more could be done. One of the biggest obstacles for the auto B6 guys is that the options for the B5 and B5 S4 are NOT available for the B6.
    Dec 06 2007
    ^^so Why Are There Question Marks Where Ur Dyno #'s Are???????
    -Kirk
    Sep 20 2006
    MD
    Cause I have new numbers and they're higher BUT I also don't have a copy of the runs. I'm waiting for the shop to get its printer fixed! LOL
    Dec 06 2007
    ^^who Cares About The Sheets #'s Please!!!!
    -Kirk
    Jul 07 2004
    socal
    Are they stuck in 1980. They have heard of email right?
    Odd, pretty sure I saw a post about there being a TIP chip for the 02. Isn't the tip chip mainly just change the amount of time it takes for each shift? I dont think they design the tip chip with a BAT setup in mind
    Sep 20 2006
    MD
    I've been waiting on that email for a week and it hasn't happened. Don't know what's going on at that shop but I'm cool with going back and getting a hard copy...once their printer is operational or they get a new one.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    sweet! hopefully you've broken into 11's now!
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Jul 07 2004
    socal
    Quote Originally Posted by A4TL View Post
    11's with a B6? I dont even think anyone has hit 12.5 yet with a B6. Going to take way more then a GT2871r to get a B6 into the 11's.
    Dec 06 2007
    ^^unless it's towed by a Bugatti!
    -Kirk
    Jan 03 2008
    Carson, CA
    has jet jockey ever done a drag? im curious to see his times with his 1000lb. audi
    Cal State University Dominguez Hills
    Dec 06 2007
    ^^still building!
    -Kirk
    Jul 07 2004
    socal
    Quote Originally Posted by setay View Post
    1000 lb? It would have to look like swiss cheese to even come close to that. Marc's S4 fully gutted to a sheel with a driveline and 1 seat was still 2500 lbs.
    His best run was way back in 2006 which was 13.3 at 107 mph, that is still a long ways away from 11.99
    Jan 03 2008
    Carson, CA
    my post was a blend of exageration and sarcasm... no worries
    Jun 30 2007
    Raleigh, NC
    such a sad truth maybe that'll change this summer/fall....
    i hope atleast ONE of us can get into the mid/low 12's...
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 06 2007
    ^^if shawn installs his R32 turbo and can get the tires to stick when he does a run he can get to the 12s at least!
    -Kirk
    Jul 07 2004
    socal
    well I sure hope he has plans for slicks if he expects any traction with 400whp on a FWD car. I think he is just looking to get into the 13's first.
