Results 1 to 15 of 15
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    MP3 files - SD Card vs. CDR
    I have the Bose with Nav/iPod on My '08 and I recorded a CDR full of MP3's (loose files- no folders) and after I inserted the disc, only the first 2 files showed up on the screen Next, using a pc, I then copied all files directly from that same CDR onto an SD card. After I inserted the SD Card into the slot, all files displayed and played without a problem. Anyone experienced a similar phenomenon?
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: MP3 files - SD Card vs. CDR
    did you use a mac in the first place?
    May 21 2008
    Not a Mac user. I'm running Win XP and I recorded the CDR with Nero. I'm pretty sure there's nothing wrong with the CDR since I was able to copy the files using a diferent P and I was also able to play the disc on a different CD player.
    Mar 27 2008
    06 A4 2.0T Q MT, Jeep GC
    PA
    ummm does the latest version of the RNS-E read MP3 files at all besides on the sd card???
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Stop wasting cents on CDs. Just use a SD card, you can have folders and everything too.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by INTEGRATION View Post
    I agree with this, however you can get re-usability out of CD's (CDRW's). You have WAY more room to expand on a SD card. I think a lot of this problem is the POS stock head unit.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    I had a similar problem. My friend burned a mp3 cd for a trip we took a while back and only the first couple of songs played. The others showed up, but it would just skip through all of them. I think he said that those songs were in a different format but I can't really remember...
    Does anyone know what file types the head unit will play for the SD cards? Sometimes when I load songs onto an SD card a couple of them don't show up at all. I think this is due to them being a different format?
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    May 21 2008
    Thanks, I just ordered an 8GB SD Card and hope I won't have any issues with it. Glassnpowder: All MP3 files are basically the same, however the compression might be different i.e. constant 192bps vs. VBR (variable bit rate). Also some files might be missing ID3 tags which have different versions too. Basically from my experience with pc music, if a player reads MP3's, it should be able to read all of them, unless the file is corrupt/incomplete. Other than MP3 and WAV (uncompressed windows format), I don't use any other formats, but some of the popular ones are AAC (Apple) and WMA (Microsoft).
    Mar 07 2008
    Audi A4 B7
    VA
    Thanks for the info. I actually think that the mp3's that don't show up are in WMA format... I'll have to check that out when I get home from work today.
    Veteran Member Three Rings djvice's Avatar
    Mar 03 2008
    Nissan Frontier Nismo, Lexus IS350, Smart fortwo
    Laveen, AZ
    How can you use an SD card on our stock OEM headunits?
    May 16 2008
    Chattanooga, TN
    SD cards, do the MY 08's now read SD high density cards, I thought the limit was 2GB
    hope they do
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by djvice View Post
    If you have the audi navigation plus, the screen folds out and down. Behind it are two SD card slots as well as your navi cd slot/mp3 cd slot.
    May 21 2008
    Quote Originally Posted by hbeing View Post
    hope they do
    I just ordered an 8GB card (SDHD) from Newegg, so we'll see when it gets here. I don't see why it wouldn't work. Must give thumbs up to Audi for this feature, since many other manufacturers put in 10GB hard drives that require you to rip your CD's in the car vs. copying files using your PC.
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    SD High Capacity (SDHC) cards WILL NOT WORK in the RNS-E. Only regular SD cards will work properly. The largest non-HC SD card you can get is 4GB. Check out www.navplus.us if you want more info, there is more information than you could ever want about SD cards and MP3 playback.
    May 21 2008
    Quote Originally Posted by TSlice View Post
    I guess you're right. I have to order another one then.
