Results 1 to 14 of 14
    May 25 2008
    North Carolina
    Headlight condensation help...please
    I've done a few searches on a bunch of different forums and cannot come up with a definitive answer on the subject. Both of my headlights get crazy condensation when it rains or via washing. Have any of you had any luck with warranty replacements or is there a fix. Thanks for your help.
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Re: Headlight condensation help...please
    I think I remember reading that people get them replaced under warranty.
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    do a search over on audiworld and on google for "the o ring fix"... its what I used to fix my condensation issues, has worked very well for months now
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Established Member Two Rings 1145climber's Avatar
    Jul 04 2007
    MA
    both of the headlights on my B6 S4 fog completelyyyy REGARDLESS of the time of day. i've seen it during a rainstorm, in the early morning, in the middle of a hot summer day, even after driving during the daytime or night time with my headlights on for at least an hour. mine just won't go away...
    my dealer claims that "slight fogging" is a known and normal issue and that they're not allowed to replace them under warranty for this reason. they also say that the fogging should go away after leaving the headlights on for a few minutes. however, i keep trying to get them to replace mine because my issue is neither slight, nor does it go away.
    i'm gonna try the o-ring fix some day soon
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Quote Originally Posted by 1145climber View Post
    The condensation is supposed to go away after 10 min of operation if not and you are under warranty they should be changed. If they do not I would tell them that you plan on contacting AOA. A lot of dealers only care if it affects their service ratings. My dealer has change 3 all they did was take a pic of the light fixture and the vin and it was approved.
    Jul 04 2007
    MA
    Quote Originally Posted by B18b1ex View Post
    awesome, i'll try this out next time, thanks for the tip.
    Dec 20 2006
    CAN
    Alternative is to take out the light housings and seal them yourself with something appropriate like silicone. I did this after the clear corner mod, no fogging at all.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Jul 02 2004
    FL
    Quote Originally Posted by CanuckRS4 View Post
    The only problem with that is if your car is still under warranty, if you open them they will no longer be covered. Also since you did the cc mod you probably were not going to be covered anyway.
    May 25 2008
    North Carolina
    Thanks to everyone for your input.
    Oct 19 2005
    Virginia
    the o-ring fix cures ANY condensation issues 99% of the time... If I can find a link to it I will post it... The thing that took the longest was removing the condensation from the headlights before actually performing the fix... requires minimal tools, and once the condensation is gone, takes all of 20 minutes... All parts were purchased at my local Lowes but any hardware store should have all necessary parts
    -Cliff
    Current:
    May 03 2008
    Audi S4 2005, honda 600 rr
    on b6 thay have vents for those lights, cuz of high heat coming from the light itsself that's what couse the fogging.
    Oct 19 2005
    Virginia
    OK, I found the link I used to fix mine on AW... This is the link.
    And for the lazy... I underlined the two parts you will need to purchase...
    Hope this helps
    Quote Originally Posted by derleicaman from Audiworld
    Like everyone else, I had the dreaded problem with my S4 Bi-Xenon ecode headlamps fogging up whenever it rained or there was high humidity. I never noticed this with my original DOT Xenon lights. I have had the S4 Bi-Xenons on the car for a little over a year now, and the problem seemed to be getting worse over time. I finally did the "umbrella" mod a few weeks ago and this seemed to solve the problem for a few days, but then sure enough, the driver's side started to have a little bit of fogging again. I resolved to do the "O Ring Fix" next, especially after the owner of the shop where I have my car worked on gave me a strange look when he saw my tyvek "umbrellas" over the headlights. I had just removed my headlights and front bumper in preparation for my K04 and DSMIC installation. He had a hard time keeping a straight face when I told him this was an accepted fix on the forums for the fogging problem. BTW, I obtained the tyvek by cutting up a FedEx envelope - free mods are great!
    Anyway, I purchased the O Rings from Home Depot. As described in DD's DYI, they are #6 7/16" OD and 5/16" ID. Stock #96723. You can find them in the Plumbing Aisle in a box of 10 for less than $ 2.00 - such a deal! I originally had some trepidation about removing the headlights to do this and throwing the headlights out of alignment, but they were already out of alignment from the turbo/intercooler install, so what the hell. I didn't even have to unclip the headlight harness to do the O Rings. Removed the cover to the headlight height adjuster as in the DYI, and merely pulled the adjuster shaft straight out. If you don't turn the shaft as you pull it out (sounds nasty) you won't alter the headlight alignment. It was amazing how much crap had accumulated under the cover and hole for the shaft. Cleaned all this off, removed the old O Ring and replaced it with the new one and lubricated with powdered graphite. Put everything back together and put the headlights back in. It literally takes less than 5 minutes a headlight to do this. The old O Rings didn't seem to be totally round, so this must be the reason moisture is getting past them.
    Here's the bonus. Since I did my USP bumper swap in the Spring, I had an uneven gap between the headlight bottom on the driver's side compared to the passenger's side. I realized that the plate that the headlight slides onto with the two lower fasteners has some adjustment to it. There are two Torx 30 screws on the underside of this plate for adjustment. Just loosen these and you can adjust the headlight gap to the fender. Clever Germans! This took me about another 30 minutes to get the alignment of the gap right. Altogether, less than an hour spent solving two very annoying problems.
    So far, both headlights are dry as a bone with no recurrence of the fogging issue. It amazes me that Audi hasn't issued a TSB to the dealers regarding this simple fix. Instead of telling people "they all do that" and even replacing people's headlights when they give in, this fix costs less than 40 cents in parts and a quarter of an hour in labor. It would sure make a lot of pissed off Audi owners happier!
    -Cliff
    Current:
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    I just made an adhesive tape patch and placed it over the adjustment screw holes. I used black gaffers tape and I've never had fogging in almost three years. You can't even see the tape if you are looking for it. Way easier than the o-ring fix, which did nothing for some.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Oct 19 2005
    Virginia
    Quote Originally Posted by S4J View Post
    O-Ring may have done nothing for some but, definitely cured the problem for most...
    You have any pictures of your patches, you've sparked my curiosity...
    I also must add that the "keys" to the o-ring fix are
    • thoroughly clean the adjustment screw shaft and housing
    • use plenty of powdered graphite on the new o-ring
    • finally, ENSURE YOU COMPLETELY dry out the housing of any moisture (I used my wife's hair dryer, just make sure that after you use the hair dryer, set the housing outside open as MUCH as possible to equalize the air and allow it to cool down) before replacing the o-ring and reinstalling the headlight.
    -Cliff
    Current:
