    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    N75 and N249 Location
    Booyakasha,
    I am receiving my new N75 and N249 valves today along with a new MAF from ECS due to some short circuit codes that shitted out the old ones. Where are these valves located and has anyone ever replaced them before? Anything I should be aware of or look out for while replacing them?
    Here are the codes that made me replace them:
    17955 P1547 035
    Wastegate Bypass Regulator Valve -N75
    Short-circuit to ground
    17697 P1289 035
    Recirculating valve for turbocharger -N249
    16486 P0102 035
    Mass Air Flow (MAF) Sensor -G70-
    Signal too low
    respect,
    nasty
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Re: N75 and N249 Location
    The N75 is under the passenger side engine cover next to the Y-pipe, and the N249 is under the Drivers side cover next to the ypipe on the opposite side! the N75 has three vacuum lines connected to it, there are the shitty onetime use clamps on them so you will probably need new clamps.. i believe the same is true with the N249, although i have never replaced or removed it! hope that helps
    Oct 31 2006
    Awesome, thanks man. Hopefully these new sensors fix the problem.
    Also, does anyone know where the intake camshaft position sensor (g40) is?
    There is a short circuit to this as well.
    2007 911 Turbo 6MT
    Oct 31 2006
    I took a look under those engine covers and can't seem to distinguish which valves are the n75 and n249. Anyone have a picture of what it looks like, preferably circled or highlighted from an engine pic?
    I wish these valves can just be bypassed, sort of like the VSV's on a supra.. can they be? I know people run an MBC in place of the N75, but I'm only on K03's. Can the N249 be bypassed so I don't have to worry about this crap anymore?
    2007 911 Turbo 6MT
    Sep 20 2007
    norwich
    here is what the N75 looks like
