Results 1 to 9 of 9
    Apr 11 2008
    York, England
    B5 RS4 brakes advice
    Hi Guys, I have been offered a B5 RS4 front brake setup, can anyone confirm whether these will fit a B6 running on 19" RS4 (B7) replicas? Thanks
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: B5 RS4 brakes advice
    I thought they were the same as B5 S4 brakes? If so you can call whatever company (Hartmann, VMR, etc.) you are buying the wheels from and ask. I'm sure both fit B5 S4 brakes
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by akaEsCo01 View Post
    They are the same thing as the S4 brakes.
    Dec 08 2006
    Jersey
    That's what I thought, thanks for the clarification
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The B5 RS4 brakes are not the same as the B5 S4 brakes. The rotors are 360mm vs 321mm and they use a different caliper. You might want to talk to Sandspeed about them. He had a set last year and might have some pictures.
    Apr 11 2008
    York, England
    Cheers for the comments guys, the discs are 360mm as Condo says
    Apr 18 2008
    leicester UK
    Yep massive 360mm discs and Big ass Calipers.
    A friend of mine has put them on his and he has no issues at all with 18" alloys on his B6 so your 19s will be ok!
    Apr 11 2008
    York, England
    Quote Originally Posted by raartoot View Post
    Do you know if they use the S4 carrier to mount the Calipers?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by steve_malton View Post
    The B5 S4 carrier and calipers are one piece.
