Results 1 to 6 of 6
    Apr 08 2008
    Toronto, Canada
    Koni Coilovers knocking sound
    I installed these on the weekend on my B6 and find that I here "clunks" once in awhile coming from the front strut, drivers side. Reason?
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Apr 08 2008
    Toronto, Canada
    Re: Koni Coilovers knocking sound
    Did a search, I think I found my answer.
    Mar 27 2005
    The Cold North
    front upper strut mount nut is probably not tight enough.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Apr 08 2008
    Toronto, Canada
    I'm going to try to reload the suspension and tighten it again this weekend.
    Established Member Two Rings r3dcloud's Avatar
    Feb 19 2007
    Audi A4,Mercedez SL500, BMW528i, BMW535i, Subaru WRX STi, VW Jetta
    Anaheim,CA
    yeah make sure you tighten everything i had the same problem in my right rear and it was a loose bolt
    2007 2.0T Automatic FWD A4
    MODS COMPLETED** Alpine IVA-W200 HU//RockFosgate 12" T1's//Focal KF series Components//Rockfosgate 1000*2 & 800*4 amps//20" Modulare M7 Wheels//KW V2 Coilovers//Vorsteiner CF Hood//Votex 3 piece spoiler//Smoked Tail Lights//Britalman Quadtip Exhaust//GIAC 91 program//S4 rear valence//Tint
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Tighten everything loaded up (ie car sitting on jack stands).
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
