Results 1 to 15 of 15
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    Post Autoblog's Latest: MTM supercharges the Audi S5
    Yes, we've already heard. but, just posting the latest from Autoblog.
    In continuation from audidriver4ever's post(10/07), sorta:
    http://www.audizine.com/forum/showth...&highlight=MTM
    The Audi S5 is no slouch at 354 horsepower, but German tuner MTM isn't satisfied and has given the 4.2-liter V8 a serious kick in the pants with an intercooled supercharger package that boosts horsepower to 505 and torque to 403. That's good enough to hit 60 mph in 4.3 seconds and reach a top speed of 186 mph. MTM is also offering a high-flow exhaust system, coilover suspension system, 15-inch brake system, and unique 21-inch wheels. Hmmm... an MTM supercharged S5 or an R8? Decision, decisions.
    PRESS RELEASE:
    Motoren Technik Mayer from Wettstetten, Germany, puts the Audi S5 under pressure. As "MTM GT Supercharged" the sporty coupe's supercharged engine demonstrates impressive performance data. Together with bigger brakes, a coilover suspension and other minor changes, the result is an overall package which can take on the race track.
    Pressurized
    Watch out, when it gets loose! At the slightest pressure on the accelerator the MTM S5 GT Supercharged rockets forward with brute force. The compressor added to the Audi 4.2 liter V8 by MTM is what makes this possible. An MTM intercooler housing with integrated water cooling ensures that the engine can always generate maximum performance. Overall, instead of the stock 354 hp, there is now all of 505 horsepower at 7190 rpm available. This makes an engine output of 120 hp per liter! The torque boost by 106 to 546 Nm emerges in vehement intermediate bursts, to which the driver can get addicted. The sprint from 0-100 km/h takes 4.3 seconds, turning many super sports cars green with envy. And up to its top speed of 300 km/h it can hold its own with any of them.
    The evenly powerful, dynamic power display is underscored by a flow-optimized stainless steel sports exhaust system. The goose pimple-raising sound is released by four tailpipes, each 90 mm in diameter.
    Curve-hugging and agile
    MTM equipped its GT Supercharged with a perfectly tuned coilover suspension and in addition amended the axle geometry with higher camber angles. After the change, its driving dynamism and curve-hugging characteristics are so pronounced you never want to drive straight-ahead again. The steering characteristics are more precise and the agility enhanced, while road handling remains quite neutral.
    Braking
    Since a performance-enhanced vehicle also has to be reined in quickly, MTM improved the brake performance, too. Consequently MTM always provides the appropriate brake system for cars of all performance classes. In the case of MTM GT Supercharged, the Bavarian specialists upgraded the deceleration with a new brake system on the front axle. This is a brake system with 8-piston fixed calipers and 380x34 mm pitted brake discs. The package includes the flexible steel lines and attachments. With the system the driver can decelerate the MTM GT Supercharged from 100-0 km/h within about 35 m. The "pitted" brake discs incidentally represent a special design, manufactured especially for MTM. Typical of "pitted" brake discs are the holes which do not completely penetrate the disc. They look like and share the characteristics of a perforated disc, but hinder the crack formation which normally occurs after lengthy use.
    The small difference
    Optically the GT Supercharged does not look very different from the series model. Here MTM has gone in for understatement. Nevertheless – apart from the MTM exhaust system's pipes – the "bimoto" MTM rims take care of a look clearly distinguished from the series. The eye-catching wheels are available in "shiny silver", "titanium" and "diamond cut" finishes. MTM provides the "bimoto" rim for the S5 – as for other A5 models too – in 10.5x21" as a complete rim set together with 295/25/ZR21 tires.
    At MTM the general rule is: special wishes are met. Customization is also carried out on an individual basis!
    More information on the extensive MTM technology range for Audi-Volkswagen Group vehicles is available on the Internet at www.MTM-online.de or on the telephone: +49-841/98188-88 .
    Autoblog article: http://www.autoblog.com/2008/05/27/m...s-the-audi-s5/
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Re: Autoblog's Latest: MTM supercharges the Audi S5
    Hm...not too sure how well this will go for the engine in the long run.
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    is this the the kit that costs $40,000?
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Feb 12 2004
    HI.
    Quote Originally Posted by HeHateMe View Post
    http://oempl.us/index.php?main_page=...roducts_id=680
    Registered Member Three Rings YMJ's Avatar
    Feb 08 2008
    2001 Pearl White Audi S4
    505 HP at 7190RPM?? wat is the redline for this car??? i dont like that number AT ALL.. is there a dyno for this??
    Pearl White B5 S4
    APR Chip~APR Exhaust~APR boost Gauge
    Bosch 710N DVs
    Koni Sport Shocks~Eibach Springs
    JHM Short Shift Kit~Bimmian Titanium Shift Knob
    RS4 Grill
    18'' RS4 Hyper Black Rims
    Interior Xenon Kit ~ 10 K HID Kit
    FREE 10SecS4!!
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    How can adding an s/c cost $40k? I'm sure it's amazing and everything but $40k?
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Veteran Member Four Rings Monizzle's Avatar
    Dec 27 2005
    Mercedes S550, 2012 Audi A4 quattro
    how it works:
    supercharger kit = ~6grand
    european luxury car mark-up = $34,000.
    in reality, why this kit is trying to be sold for this much is beyond me. at 100 grand i'll take something other than an audi without a warranty.
    hint: it's a coupe, it has a v10 and is already available with 507hp + warranty.
    Stage 2 Banner Advertiser Four Rings Tommy@Nemesis's Avatar
    Feb 07 2006
    RS3 LMS/A5 Race Car/Ascari RS5
    East Coast
    Am I the only one who is liking MTM less and less? They're prices are out of this world and their cars look terrible. They do know Audis better than anyone, but I'm not always a fan of the finshed prioduct
    Veteran Member Three Rings KevinS4's Avatar
    Apr 05 2004
    2022 S4, 2001 S4 Avant, 2021 RS7, 2014 GT3
    Miami, Florida
    Quote Originally Posted by Tommy@Rival View Post
    I agree with you Tommy. The prices are outrageous.
    Current: 2022 S4
    2021 RS7, 2001 S4 Avant and 2014 GT3
    Previous: 2011 A4, 2004 S4 Avant, 2000 S4, 1981 Coupe, 2016 A7 TDI, 2014 S4, 2019 S5
    Feb 08 2008
    and the performance from the supercharger i dont think is godo at all!!!
    Pearl White B5 S4
    Bosch 710N DVs
    RS4 Grill
    FREE 10SecS4!!
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Quote Originally Posted by Monizzle View Post
    M6?
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    kudos to them, but when did they start making superchargers out of gold? probably the most expensive tuner in the world? you would think they were creating products for ferraris or something. they must have a spinning wheel and whatever number it stops on is the final price of the product....just makes no sense to mark stuff that high.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Veteran Member Three Rings ColinAndrews's Avatar
    Oct 29 2007
    Edmonton, Alberta, Canada
    It raises an interesting question to me though.
    Why does no one compete with them? Why are there no other tuners making affordable (and in this case to steal all their business all they would have to do is make one that is 20K) superchargers for high end Audi's?
    As for the M6 thing, if you take out the warranty issue, which i know is yes, a big issue, holy shit would i rather have a 500hp S5 than an M6. Enough so, that I would actually consider an S5 + this charger over an M6. Most of that though, is because i don't like the exterior or interior or ridiculous gearbox of the M6.
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    German tuning companies are all fairly expensive. Look at brabus for MB You buy a AMG MB for 200000 Euro give them another 100000 euro and you end up with a brabus monster.
    Also when you are paying 56000 Euro (88000 US $) for you S5 its not as bad it only half the price of the car.
    | APR KO4 | APR TP | APR FUEL PUMP | CARBONIO | AWE CBE | S4 DOORBLADES | BBS Ch | TINT | KW V1 | BSH PCV STAGE II | HOTCHKIS F/R SWAYS |
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    Yahoo... something I can do when mine arrives!
    Lover of all things motorsport, powersport, sport.
