Results 1 to 3 of 3
    Lurking Member
    May 17 2008
    PA
    FS: 2001.5 Pelican Blue A4 1.8tqm $8250 OBO
    Here she sits as of 05/24/08:
    Detailed Exterior Pictures
    Detailed Interior Pictures
    $8250 - With APR Chip
    $7800 - Without APR Chip
    Pelican Blue '01.5 A4 1.8tqm
    -Approx 129,5xxk on the ODO...
    -Mobil 1 0W40 since 72k
    -Zaino Brothers twice a year since '05 (last application was in October)
    -Celebration Package
    -xenon's, OEM 17" RS4 style wheels (kdw2 tires Currently Installed)
    -Bose Premium Audio
    -Phatbox MP3 player w/ 20GB drive--(SOLD)
    -Gray interior Cloth Sport seats
    -Heated Front Seats
    -ESP
    -15% Suntek Charcoal Tint
    Upgrades:
    -All weather floor mats and OEM floor Mats
    -Fully loaded APR Chip (91, 93, 100, Valet) W/ Testpipe and left foot braking Software
    -Labree Motorsports 3"-2.5" tapered Test Pipe--(No longer installed, but available)
    -Boost Factory Manual Boost Controller--(No longer installed, but available)
    -APR Motorsports Turbo Inlet Hose--(No longer installed, but available)
    -APR Motorsports Throttle Body Hose--(No longer installed, but available)
    -A8 Brake Upgrade w/ Pagid Blue Pads F&R and Stainless Lines
    -RS4 Motor Mounts
    -RS4 Trans mount w/ new A4 trans mount
    -APR Snub Mount
    -Unorthadox OFE Stage IV Clutch w/ SS Pressure Plate
    -Replaced Slave Cylinder during clutch install
    -Input shaft seal replaced during clutch install
    -Flushed Brake Fluid and clutch
    -Redline Trans Fluid & Rear Diff Oil
    -Fog light switch mod (allows for f/r fogs to be turned on without the headlights on
    -Dual Rear Fog lights (Tailgater Eliminator Mod)
    -S4 Drivers side Wheel Well Liner
    Maintenance Items:
    -Timing belt (full kit) done at 72k after purchase (Due at 132k)
    -Air Filter and pollen filter every 10k
    -New MAF sensor due to K&N Filter oil contamination
    -New 710N Valve
    -New N75 Valve
    -PCV System Replaces with new hoses (all except one way check valves): Suction Jet Pump etc.
    -M1 and Large Filter every 5k in Florida, 3k here in PA due to short drive to work and winter
    -Fluids Replaced in Florida before moving up to PA at 125k: power steering, Coolant, Oil, Brake Fluid Flush
    -Spark Plugs replaced at 125k
    -Fuel Level Sender replaced at 125K
    -Front Drivers side CV Joint replaced at 125k
    -Cam Chain Tensioner and Seal Replaced (turned out not to be bad, ended up being an exhaust leak at the Exhaust Manifold)
    -Valve Cover Gaskets
    -Exhaust Gaskets replaced (manifold, turbo, Cat)
    -Intake Manifold Gasket
    -Coolant flange replaced (cracked and was leaking fluid)
    -New Coolant Reservoir installed (original included)
    Exterior:
    Car has only experienced one winter in PA, the Previous owner bought the car in Atlanta, moved to Colorado (car remained in garage during winter) for one year, and then moved back to Charelston, SC where I purchased the vehicle in '05. It was a Florida Only car from '05-October '07, and has been in PA since then. was washed each week during the snow of winter to get rid of the Salt that PA uses on the roads, and every 3 weeks otherwise.
    -No Serious dents to the exterior. Minor dent on the passenger side next to the trunk lid. (See picture: Here)
    -No Serious scratches to the exterior. Light scratches on the front/rear bumper, light to med scratches on the c pillars due to Snow Brush from PO. Absolutely no rust anywhere on the vehicle.
    -PO causes some paint to be removed along the door frame on rear passenger door. Sealed and painted. No issues since I've owned her. (see picture: Here)
    Interior:
    -Suffers from leaky Sunroof drain on the drivers side C Pillar. Leak has caused adhesive from the C-Pillar to seep out and wick down the side cushion for the back seat down to the horizontal surface. Simple shampoo should remove the adhesive residue, however the drain hose should be replaced.
    -DIS screen has begun to degrade since last summer. External Temp, Radio station, and DIS section are readable, but not complete.
    -Drivers side front Door Speaker sounds like the cone as torn. This just occurred last week (04/24/08)
    Accidents:
    The only incident this vehicle has been in is I hit a raccoon at about 35MPH on the drivers side back in December '06 that cracked the Washer Fluid Reservoir (slow leak that did not become apparent until 1 week later). I pulled the front bumper and intercooler to inspect everything and found no damage. The fog light support was cracked in the bumper and the fog light was damaged. I replaced both fog lights.
    The car only has the following mechanical issues:
    -Windshield Washer Fluid Reservoir is cracked.
    -First gear is noisy since October '07 and sounds like the synchro is the source. Has driven fine with no issues (spirited and normal driving)
    -Drivers side Tie Rod end needs to be replaced.
    -While removing the Test pipe this weekend, I noticed that the Passenger Side CV Joint is leaking grease...
    -Passenger Side Fog light Grille missing due to quick entry into a neighborhood that had a 1 ½ inch lip due to construction. Didn't notice it was missing for 3 days...
    -and the Oil Dipstick handle is broken...stupid orange plastic ring...
    Additional Items:
    -Cargo Net out of my old '97 (the one with straps not just the elastic one)
    -Matching full size spare (RS4 Celebration wheel)
    That's everything I can remember at the moment.
    Depending on interest, I may go ahead and pull the Test Pipe out and reinstall the CAT, Reinstall the APR Hoses, pull the Phatbox, and see if anyone wants to swap ECU's for the Chip, but I would definitely prefer to sell it as is.
    Feel free to email me ([email protected]) for more info or pictures.
    Lurking Member
    May 17 2008
    PA
    Re: FS: 2001.5 Pelican Blue A4 1.8tqm $8250 OBO
    Morning Bumparoo
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    bump for a pelican
