Results 1 to 14 of 14
Thread: boost leak test
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    boost leak test
    After reading the write up "finding a boost leak" on a4mods.com figured I'd give it a shot.
    http://a4mods.com/index.php?page=web...boostleak.html Thanks martini
    1) Inserted my pressure tester in the TIP.
    2)disconnected the PCV return from the TIP (note: on my car the check valve was closer to the firewall. Not on the TIP like the write up followed)
    3)I started to charge the system, and at 2~3 psi I started to hear a weird sound. Kind of like boiling cooking oil... hard to explain...
    So I ended the test immediately.
    The noise is similar to what you hear in the background ( 00:18-00:31)
    http://www.youtube.com/watch?v=ryfwz...eature=related
    Anyone know what that sound is and if it's normal or not?
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Dec 19 2007
    York, PA
    Re: boost leak test
    sounds like a deep fryer..weird, not sure if its normal or not.
    Active Member Two Rings Kerr's Avatar
    May 22 2008
    2004 A4
    FL
    Re: boost leak test
    I've done plenty of leak tests on Evos and I have never heard anything like that before. Can you tell where its coming from? Do you have a picture of the tester hooked up?
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: boost leak test
    I think you may have disconnected the wrong hose... its probably oil bubbling from pressurizing the crank case
    when you started it did it smoke out the exhaust?
    double check that you disconnected the right thing on the TIP.... it shouldn't be in a different location if you are an AMB 1.8T
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: boost leak test
    Quote Originally Posted by martini View Post
    It sounds like oil bubbling, and no smoke out the exhaust.
    what goes from the TIP to the back of the engine? No check valve on my TIP...onlt a tube with a braket bolted on the engine to what I tought was the check valve. I will take pics tomorrow.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: boost leak test
    this is the best picture I have.... you want to disconnect and plug the PCV somewhere in that path
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: boost leak test
    Yup, that's what I did..except the pcv return valve is not directly on the TIP. A tube comes out from from the TIP (red line) and the valve is located in the top left corner of your picture.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Re: boost leak test
    If you have blocked all the appropriate intakes and the hose from the IC to the Throttle body (at the TB that's not in the pic above)....Then just a guess...since your car is an 04 (possibly with a few miles on it) you may have a leak in your OEM intercooler. The endtanks are known to leak and in worst case seperate/blow off; infact I just had this issue on my car ('02 w/ 57k miles).
    Oil builds up in the lower intercooler hoses and the intercooler over time and miles and this maybe what you hear bubbling through a leak. I'd also look for oil residue/blow by everywhere around the piping and intercooler: it'll lead you right to the leak if that is indeed the case.
    oh and BTW the pic above from Martini is from an 02 1.8t where the PCV return valve is attached to the TIP, newer ones have it up where you stated.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: boost leak test
    My car is the same way. The PCV valve is not on the tip, it's on the back of the head and honestly I have never seen it on the tip except for your car Martini. My car is an 03.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: boost leak test
    Quote Originally Posted by jessefrank View Post
    I'll take a deeper look tomorrow, when I heard the boiling/bubbling sound I decided to stop there (started to rain).
    And thanks for the location of the valve. At least I'm not crazy lol.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: boost leak test
    i worried when i heard bubbling, but i read on AW that someone else heard the same thing. i found and fixed my leak and havn't had a problem since.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: boost leak test
    if you get a lot of bubbling, there is a chance that you could put some oil in to the exhaust... you will have it burn off, but just let the car idle and it will clear up.. .no worries
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: boost leak test
    Quote Originally Posted by A4 TSCHUSS View Post
    Mine was and still is on the TIP.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    Re: boost leak test
    they must have only done it for one year on the B6 and decided that was a bad location and put it on the back of the head where all are except the 02 im guessing.
    ~David~
    CTS-V 9.6@148
