Results 1 to 14 of 14
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    B6 A4 doors aluminum or sheet metal?
    Having a body shop repair my door and replace my fender. They told me that the door will need to be replaced entirely because you cannot purchase a door skin and it cant be straightened because the door is aluminum and bondo wont bond to it. Any truth to this?
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: B6 A4 doors aluminum or sheet metal?
    I'll ask tomorrow at the stealership (unless someone else confirms first) but I'm sure your guy gave you the straight dope.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Dec 19 2007
    York, PA
    i doubt its aluminum but just have them replace the door anyway. Id rather have a new door skin than one thats bondo'd up.
    Junior Member Two Rings LTrain2273's Avatar
    Apr 01 2008
    Minneapolis, MN
    Same thing happened to me, they replace the door skin and apparently sucked at getting the door gaps right. So I complained and they fixed the gaps. PITA!
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Put a magnet on it, no stickey=aluminum
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    They must be thinking of the A8, I do believe it uses aluminum in the fenders and hood. Doors, I don't know though.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    A4 door skins are steel.
    Apr 16 2007
    Queens
    So they do in fact have door skins? So theyll probably change the door skin and fender?
    2003 A4 1.8TQM
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    It's steel and there are no skins for these cars, you have to replace the entire door. He might be saying he won't bondo it cause he's a good guy like the one I know. He said he won't bondo it cause then you'll have a wad of bondo on your door and he refused... The other guy hit me so he was paying for it so I said sounds good... but no skins for these cars.
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    They are not aluminum.
    A magnet sticks to them. I know this cause I got an air pressure gauge that is magnetic and had it stuck to my door the other day.
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    That sucks, I wonder why they did it? Cheaper?
    Veteran Member Four Rings JJPA4SE's Avatar
    Boxes
    Pittsburgh, PA
    Quote Originally Posted by T0M3K View Post
    Structural integrity and maintaining audi's standards w/o the chance of a body tech half assin it...
    Also, 'bondo' isnt all bad as long as the tech does a good job metal shaping the damaged area prior to applying it. For the most part the industry standard is no more than 1/8" (3mm) thick is acceptable. If it were my car i'd like it as thin as possible though. Even new cars come w/ 'bondo' on them...
    2001.5 S4
    2005 Acura RL - SOLD
    2006 S4 - 25quattro #159 - SOLD
    2005 A4 1.8tqm Ultrasport Avant - SOLD
    2005 A4 1.8tqm Special Edition - SOLD
    Registered Member Two Rings SouthflA4's Avatar
    South florida
    There metal AND bondo will adhere to them. Simple fact.....I am body man at a local body and I own an 04 audi a4 which i personally banged up a few times and have fixed and painted myself. If they are telling you it wont work, you probably shouldnt even let them touch your car....lol. Anything else just let me know.
    Dec 19 2007
    York, PA
    ^they probably just dont want to be liable if the bondo starts to warp or crack
