Results 1 to 7 of 7
    Dec 06 2007
    problems need be resolved!
    Yo i got a few probs as always that need some Audizine TLC!
    1.) AVG. MPG METER RESETS EVERY TIME I START THE CAR, AND NO IT ISN'T THE INSTANT MPG, STARTED AFTER I CHANGED MY BATTERY!
    2.) Vibrations through pedal area! not only from exhaust!
    3.) Under hard braking i feel my wheels turning through my brake pedal and it creaks!(Have bad CV joints, is this the cause??)
    my freakin gauge area where the wrench, and odo. buttons are squeaks like crazy!!!!!!
    Thanx Brosephs!
    -Kirk
    BetaAlphaTau Member #58
    Dec 06 2007
    Re: problems need be resolved!
    anyone??
    -Kirk
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    1) There are two sets of averages in the trip computer, one is per-trip and resets after the car sits for a couple hours, and the other is ongoing until you reset it yourself. The corner of the display will show "1" for the per-trip measurements and "2" for the ongoing measurements. You can use the reset button on the wiper stalk to switch between them.
    2) Vibrations when the car is moving, or idling? Moving could be an unbalanced wheel. Idling can be plugs, coil packs, idle too low, or any of a number of other things.
    3) Warped brake rotor(s). CV joints could be a factor too.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    Dec 06 2007
    ^^thanx but read the post dude, it sayd the avg one with the crossed out zero keeps reseting, and it only happens when i'm moving and it's in the pedal area!
    -Kirk
    Jun 30 2007
    Raleigh, NC
    he did read the post, one of them will reset on its own, and one resets when you take the time to reset it. go click (not hold down) the reset button and look at how it cycles through. Why didn't yours reset before? you probably just didnt notice it. idk.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 06 2007
    ^^ooooooooooooh! k gotcha if this works u guys like rule!
    -Kirk
    Dec 06 2007
    thanx guys the MPG thing worked u guys rule, it was driving me nuts! thanx again!
    -Kirk
