Results 1 to 29 of 29
    Dec 19 2007
    York, PA
    2003 5 Speed Tranny Drain Bolt Size?
    I cannot figure out for the life of me which triple square bit i need. I bought a 10mm one today at NAPA, and first of all, WAY too small. Secondly, I also need a bit with the center drilled out (security bit). Do i need 12mm or what? I found a 16mm on ebay, but i would think thats too big...some help please.
    Established Member Two Rings setay's Avatar
    Jan 03 2008
    Carson, CA
    Re: 2003 5 Speed Tranny Drain Bolt Size?
    its the 16mm 12point. i bought the one off of ebay. but you need to be careful, ive read of 03's being equipped with different plugs. aslong as you know that its the 12point with the security pin in the middle of it, you're set.
    Dec 19 2007
    York, PA
    yea, i know it has the security pin in the middle, its gold in color...anyone else chime in...i dont want to order one and have it be the wrong size.
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Dec 19 2007
    York, PA
    yea, i saw that earlier today, it does not list the size, just that its a 12-point bit. I really would not like to spend $28 for one plus shipping.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I can get a measurement for you tonight. I have one in my basement.
    Dec 19 2007
    York, PA
    awsome, thanks man, your help is greatly appreciated.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    From point to point it looks to be 15mm.
    Dec 19 2007
    York, PA
    i was hoping you'd say 16mm...i dont think there is a 15mm triple square bit...lol
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Well, the only thing I had to measure with was a regular tape measure.
    Dec 19 2007
    York, PA
    well, wtf, i expected an exact laser measured length...sheesh...jp...thanks
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    It's a good fit for a 12 point 14mm socket. A little loose in a 15mm socket.
    Dec 19 2007
    York, PA
    so that would make it a 14mm 12-point bit right?! if so, we got a winner
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    That should be it as long as you can find a security bit.
    Dec 19 2007
    York, PA
    haha, wish me luck
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Cock I just bought the oil for my tranny, I thought it was a 17mm hex... damn it :( so the verdict is a 14mm TS with security hole?
    Aug 14 2007
    Ottawa, ON, CA
    The tool is a 16mm TS with security hole
    Dec 19 2007
    York, PA
    you picked one up and it works?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by n7plus1 View Post
    Are you planning on picking one up in person? If so, just do a test fit to see if it fits in a 14mm socket before you buy it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You could just buy this, wait a day or two for it to arrive, and be done with it:
    http://germanautoparts.com/tools/Aud...sion%20tools#1
    Works perfectly fine for me.
    -Doug
    Dec 19 2007
    York, PA
    well, ok, so this is the problem...ive gotten in contact with snap-on and they are telling me from their paperwork that a 16mm is the one i need...but ^i contacted germanautoparts.com and they told me:
    "Nate,
    To the best of our knowledge and according to the Vw/Audi parts guide you should require this tool below for the transmission drain plug."
    (Which is the one you have pictured above)
    and
    "Nate,
    I took a quick look, it does appear to be a 14mm. Definitely larger then the 12mm commonly we stock."
    SO I STILL HAVENT GOTTEN ANYWHERE!!!
    Dec 19 2007
    York, PA
    could i borrow yours...pay to ship it to me and then, when im done, ill ship it back..that way, if it doesnt fit mine, not a big loss..other than shipping charges.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    If you want. I won't be able to ship it out until Monday. I guess no one near you has it?
    When can you get it back to me? I will need soon for I plan on modifying the center diff in my 2.8L 5spd trans and replacing all of the fluid in that before it goes into my Avant.
    -Doug
    Dec 19 2007
    York, PA
    thats fine...ill pm you
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    For the archives, I bought this tool from GAP and measured it with a micrometer. It is a 16mm security triple square, not 14 or 15. The allen size is obviously a 17mm for the fill plugs and for the diff plugs, and the center section (used to turn it) is 19mm. Thus, you need this tool and a 19mm box wrench or socket, and you're all set to change the fluid. A hand pump from Walmart is also helpful, and essential for the diff as you cant snake in a hose from above b/c there is no access from the top like with the trans.
    You can also get it from www.metalnerd.com for $25 + shipping, which is about the same price.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    is this the same for a 6 speed? (mine is an 04)
    Back from the grave....
    Dec 19 2007
    York, PA
    Quote Originally Posted by lookaught View Post
    thank you...i still havent gotten around to doing this...
    Active Member Two Rings henriquevr's Avatar
    Oct 11 2010
    Sunnyvale / California
    I will need help (garage and lift) to change my tranny fluid, have all the tools and beer.
    Anyone in South Florida?
    Registered Member Two Rings
    Oct 03 2010
    UPSTATE NY
    Double check that you ABSOLUTELY need this part. I bought this part from Germanparts.com because everyone said to. I have on 02 manual 3.0 quattro. Both bolds on the transmission came off with your standard allen wrench.
    2002 A4 Quattro 3.0 Manual Dolphin Grey Pearl
    Upstate NY
