    May 23 2007
    sfbay area
    brake piston seals
    I replaced my rear brakes and rotors the other day and I found torn piston seals on my caliper. Has anyone replaced these seals?
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Re: brake piston seals
    Actually there are 2 parts. The dust cover boot and the actual seal inside the caliper. In my experience, the fronts are way easier to change. If you do the rears, you'll definately need the tool that screws the piston back into the caliper. It was quite a pain in the butt to do.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Screw that it's really fricken easy. I've done it to both my B5's. The seals are like $5.85, that's for all four pieces.
    May 23 2007
    sfbay area
    Quote Originally Posted by djwimbo View Post
    $5.85? Where did you find that? I just bought the rear set from the dealer for $35.00 and it came with this pink fluid for presoaking the seals. Was your kit similar?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by justanaudi View Post
    I lied, it was $5.41
    AutoHauzAZ
