Results 1 to 10 of 10
    Veteran Member Three Rings bigmerle's Avatar
    Jul 27 2007
    2001 A6 Avant
    Annapolis, MD
    Wheel fitment guys...I need some help...
    Ok guys, looking at some oem mercedes wheels for winter/daily driving. Can you tell me if these wheel sizes/offset will fit with my A6...
    Front wheels: offset 30, 8.5JX18, tire (255/40ZR18)
    Rear wheels: offset 33, 9.5JX18, tire (285/35ZR18)
    Or
    Front: 18x8,offset is 30mm, tire (245/40R18)
    Rear: 18x9,offset is 39mm, tire (275/35R18)
    Or
    Front wheels: offset 35, 8.5JX18, tire (255/40ZR18)
    Rear wheels: offset 40, 9.5JX18, tire (285/35ZR18)
    Thanks guys....
    Jul 27 2007
    2001 A6 Avant
    Annapolis, MD
    Re: Wheel fitment guys...I need some help...
    anyone?
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    those rears are way too wide to be on a narrow body a6 imo. ud rub like hell unless u had a 4.2, mite be able to pull it off. plus i personally would try to keep a 40 series tire all the way around. running different series tire on the same sized rim wouldnt be recommended
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    audirs... what are you talking about with the 40 series..? if you run staggered you have to run different series for the wider tire, or else the awd will get fucked up... rolling diameter buddy
    Veteran Member Three Rings sempaipaul's Avatar
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    check out this website.
    http://www.rims-n-tires.com/rt_specs.jsp
    You need to calculate which set has the overall same rolling diameter so your AWD doesnt get messed up. As far as offset... I am not sure.
    -Paul
    Garage: 03' RS6 (FOR SALE); 16' 328i xDrive Wagon (FOR SALE); 13' X3 M-Sport; 05' Cayenne Turbo, 01' 911 Turbo
    Jul 27 2007
    2001 A6 Avant
    Annapolis, MD
    Thanks...that was the web site i was looking for....but im not sure what offset will work??
    Mar 22 2005
    Kitchener, Ontario
    Quote Originally Posted by projectdarka4 View Post
    yea i was thinking the rolling diameter would be different if u are running 40s in the front and 35's in the back, no? unless im misunderstanding this
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    it will be different if he has the same width in the front and the back, but if you look above, he wants to go staggered
    Nov 19 2005
    Pair of (. )( .)
    ^ i have 19x8.5 and 19x9.5 245/35 all around and overal diameter is the same! i had 40s before....275 and 285 are way to wide for 2.7t if you are lowered...
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Man, that is a cool ass link. Not that I really know what it all means, but its cool
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
