Results 1 to 24 of 24
    Registered Member Two Rings
    May 27 2008
    PR
    Built S4, How much AWHP?
    I've been searching for HP ratings on built s4's and havent come up with anything...
    My car has pauter rods,stock pistons,stock cams,ARP head and main,custom FMIC,ported head,custom turbo kit and EMS... Turbo's are a little bit bigger than T28's
    How much AWHP would you think this can support?
    What about stock crank? Drivetrain?
    Theres too much money into this and I dont want to ruin this by being misinformed!
    Because this is a specific setup I think it is fair that I post this...
    Thank You in advance
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Re: Built S4, How much AWHP?
    stock trany is good for as much as you can make.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Dec 06 2007
    Calgary, AB, Canada
    stock drivetrain will hold all the power you want, except for the front half shafts. You may twist one of those off if you leave them stock. On stock engine internals, a good bet is to stay under 550whp.
    May 27 2008
    PR
    Quote Originally Posted by The_Jerbel View Post
    Even with the pauter rods? under 550whp? 93 oct. or race gas?
    Active Member Four Rings
    Jul 17 2004
    Quote Originally Posted by darvo View Post
    He said stock internals.
    And I personally would not go beyond 500whp on stock block...people have trashed rods under 550whp. With forged rods, the sky is the limit.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    ask pauter directly and they will tell you that they dont reccomend exceeding 600whp on their rods... the bolts they use arent big enough to support anything above that..because of clearance issues they cant really use beefier hardware.
    or at least thats what i got told.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jul 17 2004
    Quote Originally Posted by JDM EJ1 95 View Post
    That doesn't sound right. The Rosten's I have are rated at 150hp/rod (900hp). I can't imagine Pauters being 300hp less.
    Alex
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    my pauters dont have 5/16th arp2000 rods bolts, I had them upgraded to 5/16 625 custom aged rod bolts, the same clamping load as a 3/8 arp2000, its about a $225 upgraded bolt option, yea, pauters have been pushed to crazy HP levels in all types of cars with there X beam design, they say 600whp because of the rod bolts and liability, I think everyone should be ok, as long as things are put together the right way. Make sure to use nice assembly lube if you are doing it yourself, it is designed to stick to metal longer so that your initial bearing surface break-ins are smoother, and follow arps instructions
    Feb 08 2008
    North Jersey
    also, I dont think ARP makes head studs for the 1.8t or the 2.7tt because of the wierd audi nut that has a 6 point vw/audi exclusive tool, the mains can just be cross referenced to any ARP stud to make your own main stud set :)
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    I'll tell you in 2 to 3 weeks from now...
    May 27 2008
    PR
    What about the stock pistons?
    Does anyone have a 600whp+ S4, other than the killerS4 from Poland?
    List mod?
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Whats bigger then "t28ss", as theres 20 different sizes? Why would you need anything larger then what a t28 can offer? GT28ss are good for 1000hp which is 450 more then what your average S4 will ever handle..
    May 27 2008
    PR
    Quote Originally Posted by generationjdm View Post
    It wasnt like I was shopping for them, they were offered in a great price!
    And couldnt resist!
    Mar 14 2007
    michigan
    And couldnt resist!
    You still didn't answer the question "bigger then t28s" Whats bigger then t28ss when there 20 different sizes? What turbo are you talking about?
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    i'm calling mega bullshit on his claims....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    May 27 2008
    PR
    Quote Originally Posted by ///M3 TO S4 View Post
    What claims?
    Whats your problem?
    I'm just asking a simple question, that does not regard my turbo setup...
    I dont have to post my exact setup to anyone...
    And I really dont even care if you dont believe me anything.
    Crybaby
    Fyou...
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    so you haven't taken the time to dyno it? or your car still in the build up stage.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    May 27 2008
    PR
    Quote Originally Posted by SoEvoL View Post
    All engine work,exhaust,manifolds,etc are done.Its just a question of torquing heads(i dont know if its called like that in english),put back in the whole front end of the car, wire up the EMS, break-in the engine and clutch, and dyno time.
    I think that the car will be starting up in 2 to 3 weeks. Then the break in process and dyno time.
    Mar 14 2007
    michigan
    Tell us what you have for turbos? Who made the manifolds/kit? How come you don't no any of the questions your asking especially if you've spent all this money to build the car?
    May 11 2008
    2001.5 S4
    Bama
    i agree, it would help, i mean were stabbing at the dark with the little info youve given us
    Keep It Simple
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    List mod?
    Eurocode and Autospeed both have S4's that are making 650+whp. I think Vast also has done a few Twin GT S4's.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    David @ Eurocode is making well in excess of 650WHP with a built motor (2.7). I personally blew up his transmission on a high RPM launch so the power limitation is right around that.
    His new transmission is fully built with cryo treated hardened gears and it seems to be holding the power.
    As far as the power train goes, it is hard to say what it will handle stock...right now the car has front and rear LSDs, DSS stage 5 axles and a twin plate carbon ceramic clutch that will hold about 850 pounds of torque (steel billet flywheel).
    May 27 2008
    PR
    Manifolds where custom fabricated, no company, nor store,etc.as well as the downpipes,exhaust,cable driven TB in stock IM.
    The turbos where bought from a guy who was going to upgrade his TT Supra.
    I dont know any of this because when I bought the car i didnt buy it for this. Instead I ended up spending more money than before..
    These cars are not very popular in PR. And I have searched through this forum and other audi one, and I didnt see any information of what I wanted, so I decided to ask.
    May 27 2008
    PR
    Quote Originally Posted by 400HPA4 View Post
