Results 1 to 13 of 13
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Those of you who have Hoen city lights EDIT: I NEED HELP!
    Are yours melted to your housing? Mine burnt out and I can't get it out. It's fused to the housing.
    Any of you guys able to get them out?
    I'll post a pic later since this thread is worthless without pics. hah
    Edit:
    I took my other one out, which is fine, isn't melted to the housing.
    Now for the other side, I can't get it out! It's part of the housing now! Anyone with ideas on how to get it out? Would some sort of heat gun be a viable option? Stick it in there and heat it up so that I can hopefully pull it out. But I'd be worried about melting other things too. Also, what exactly makes it too hot, the DRL or the Xenons? I'm thinking of leaving the lights on for awhile to try and heat everything up to get it out.
    What to do?!?!
    Aug 07 2007
    B7 ABT Avant
    Re: Those of you who have Hoen city lights
    Bump
    Nov 12 2007
    Grand Junction, CO
    There have been countless comments/warnings of this happening with the Hoen City Light bulbs.
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    uh oh. i better look at mine.
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    yea there was a big thread about it a couple months ago.. thats why people are going crazy over the new LED city lights that one of our own members is making as a solution to this problem. Sorry to hear that it happened to you, another person had to replace their set of headlights because of this.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I heard of the city lights issue thats about it. I have the rear plate and the fog light bulbs. no issues yet and going on 6 months.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Established Member Two Rings MDB7's Avatar
    Feb 06 2007
    Waldorf, MD
    when my hoens did the same thing I took a hanger and bent it so that I could get the end of the hanger (covered in ducktape) inside the opening and was able to fish the broken peices of bulb out of the headlight housing.
    2007 Black on Black S-Line B7, Revo , 30% tint, Debadged, Tinted Tails (helps with down force)
    Aug 07 2007
    B7 ABT Avant
    lol fcuk me.
    I know about the thread before, but when I checked then it was already fused to the housing anyways.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Quote Originally Posted by [email protected]
    our W5W runs too hot for the Audi housing. On the A4 the plug is close to the lamp housing so does not allow the heat to dissipate well and can cause melting. Its better suited for the Japanese cars who traditionally have wider spaces in between the plug and plastic parts.
    regards
    Andreas
    Copy/paste this to the FAQ-stickied thread please and lock
    2006 Audi A4 2.0T Quattro 6MT S-line
    Aug 07 2007
    B7 ABT Avant
    Re: Those of you who have Hoen city lights EDIT: I NEED HELP!
    bump
    Jun 05 2007
    Phillips Ranch, CA
    Hey bro,
    sad to say but this also happend to me. What I did was do the CC mod again, after taking the headlight cover completely off I used a small razor blade and slowly/carefully cut off all the melted plastic from the bulb n the housing perfectly. Then once I was fully able to remove the city light housing I took out the bulb with my hands/needle nose pliers and I then put in the OEM city light back in n tested it to see if the housing was alright. Sure enuff it was so...., I then popped it back in to the headlight housing n everthing worked PERFECT. Good Luck hope this helps. Atleast for me it did.
    Aug 07 2007
    B7 ABT Avant
    I've wanted to do the clear corner mod. But I'm too pu$$y to take the headlights apart. Maybe I have no choice now..
    Jun 05 2007
    Phillips Ranch, CA
    Yup. U have no choice my friend.... so i guess its a good thing. Dont be scared, tho i have done the cc mod several times, it should take less than 2 hours if it ur first time.
